How do I reinstall my Bluetooth driver on my Windows 10 laptop?
Reported
2020-05-06T22:59:59+00:00
I have been trying to turn on my Bluetooth for this laptop for the past 2 months and the icon is not available in the action center and I have tried any and every solution. How do I get back my Bluetooth driver?
2020-12-07T21:49:37+00:00
To troubleshoot issues with Bluetooth, check out this comprehensive video. It is broken into chapters so you can skip to the relevant section or watch it in its entirety based on where you are in your Bluetooth journey.
Below are the chapters and their timestamps in the video.
0:06 Make sure Bluetooth is turned on your PC
0:21 Check the Bluetooth status of the device you are trying to use with your PC
0:54 Initial steps to run on your PC
2:09 Bluetooth troubleshooter
2:28 Troubleshoot problems with drivers
2:45 Update Bluetooth drivers
3:37 Re-stall Bluetooth adapter
4:33 Get Help app
https://www.youtube.com/watch?v=wPCfua4U2o4
74 additional answers
  1. Deleted
    2020-07-19T22:18:15+00:00
    I MESST UP AND TOKE OFF MY BLUETOOHT FROM MY COUMPOTER
    2020-07-20T21:58:20+00:00
    how do i reinstall my bluetooth driver?
    2020-07-20T22:01:51+00:00
    how can i get my bluetooth back?
