How do I reinstall my Bluetooth driver on my Windows 10 laptop?
Reported
2020-05-06T22:59:59+00:00
I have been trying to turn on my Bluetooth for this laptop for the past 2 months and the icon is not available in the action center and I have tried any and every solution. How do I get back my Bluetooth driver?
2020-12-07T21:49:37+00:00
To troubleshoot issues with Bluetooth, check out this comprehensive video. It is broken into chapters so you can skip to the relevant section or watch it in its entirety based on where you are in your Bluetooth journey.
Below are the chapters and their timestamps in the video.
0:06 Make sure Bluetooth is turned on your PC
0:21 Check the Bluetooth status of the device you are trying to use with your PC
0:54 Initial steps to run on your PC
2:09 Bluetooth troubleshooter
2:28 Troubleshoot problems with drivers
2:45 Update Bluetooth drivers
3:37 Re-stall Bluetooth adapter
4:33 Get Help app
https://www.youtube.com/watch?v=wPCfua4U2o4
74 additional answers
    2020-09-22T01:24:09+00:00
    I got it running using my Acer Recovery Management Tool and choosing "Treiber erneut installieren" (install driver again).
    Try to find tools on your local hard disk for recovery management, according to your notebook.
    Ich habe es geschafft mein Bluetooth wieder zu aktivieren und verwenden zu können. Ich habe auf Acer Recovery Management zurückgegriffen und die Treiber erneut installiert. Danach hat es nicht gleich funktioniert und ich musste im Geräte Manager noch einmal nachhelfen.
    Sucht also auf eurem Rechner nach Software vom Hersteller, welche helfen sollte "Werkszustände" herzustellen. (Nicht mit Windows versuchen sondern wirklich explizit mit Software die auf eurem Rechner vom Hersteller vorinstalliert ist)
  2. Deleted
    2020-09-22T12:21:00+00:00
    my laptop is hp probook 6570b intel  i5 64bit opereting system
    in device manager not show bluetooth after i uninstall bluetooth driver
    please solve this problem
    2020-10-10T20:54:13+00:00
    can someone help me reinstall bluetooth please
