How do I reinstall my Bluetooth driver on my Windows 10 laptop?
Reported
2020-05-06T22:59:59+00:00
I have been trying to turn on my Bluetooth for this laptop for the past 2 months and the icon is not available in the action center and I have tried any and every solution. How do I get back my Bluetooth driver?
2020-12-07T21:49:37+00:00
To troubleshoot issues with Bluetooth, check out this comprehensive video. It is broken into chapters so you can skip to the relevant section or watch it in its entirety based on where you are in your Bluetooth journey.
Below are the chapters and their timestamps in the video.
0:06 Make sure Bluetooth is turned on your PC
0:21 Check the Bluetooth status of the device you are trying to use with your PC
0:54 Initial steps to run on your PC
2:09 Bluetooth troubleshooter
2:28 Troubleshoot problems with drivers
2:45 Update Bluetooth drivers
3:37 Re-stall Bluetooth adapter
4:33 Get Help app
https://www.youtube.com/watch?v=wPCfua4U2o4
74 additional answers
    2020-05-06T23:25:56+00:00
    I did both through going into my device manager and troubleshooting but i only says that sadly this laptop is not capable of having Bluetooth, but it does not make sense because a previous owner of this laptop has claimed that they have connected and had the Bluetooth switch on.
    2020-05-06T23:04:37+00:00
    Hello Osborne_137,
    I'm John an Independent Advisor and a Microsoft user like you. I understand you're having trouble with Bluetooth not working. What is the make and model of your device? Did you upgrade your Windows?
    Select the Start button, then select Settings > Devices > Bluetooth & other devices Make sure Bluetooth is turned on.
    Restart Your Bluetooth Radio
    If Bluetooth is enabled, switching it off and on again might resolve some underlying issues of which you’re unaware.
    To do this, click the notification icon in your Windows taskbar to access your quick settings. Click the “Bluetooth” tile to turn it off. Once it goes gray, click it again to turn it back on.
    Run the Bluetooth troubleshooter
    Select the Start button, then select Settings > Update & Security > Troubleshoot . Under Find and fix other problems, select Bluetooth, select Run the troubleshooter, and follow the instructions.
    Please visit your manufacturer's Support Page. Download and install the latest Bluetooth driver.
    Run the Hardware and Device Troubleshooter
    Press Start then search command prompt
    Right click then run as administrator
    type: msdt.exe -id DeviceDiagnostic
    Restart your PC
    Restart the Bluetooth Support Service.
    Press WIN+R
    type: services.msc
    Find "Bluetooth support service"
    Right click then Restart
    Right click then properties. check if the startup type set to Automatic
    Disable/Enable Bluetooth
    Press Start then search Device Manager
    Right click or press and hold on your Bluetooth device, click/tap on Disable device
    Right-click again then Enable
    Update Bluetooth driver via Device Manager
    WIN+X then Select Device Manager
    right-click the device, and then click “Update Driver” to search for a new driver.
    Click "Update Driver" in "Device Manager."
    Click “Search Automatically for Updated Driver Software” if you want to search for a driver automatically.
    If you downloaded the driver from the manufacturer’s website (and it doesn’t include an automatic installer), click “Browse My Computer for Driver Software” and follow the onscreen instructions.
    Uninstall Bluetooth
    Click Start and type Device Manager.
    In Device Manager, locate the Bluetooth adapter. Select Uninstall.
    Restart the machine and Windows will automatically install the driver after log in
    Fix Bluetooth problems in Windows 10
    https://support.microsoft.com/en-us/help/14169/...
    Turn On or Off Bluetooth Wireless Communication in Windows 10
    https://www.tenforums.com/tutorials/33807-turn-...
    I hope this helps! Please let me know if you have any further concerns.
    Sincerely
    John DeV
    Independent Advisor
    Standard Disclaimer: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
