Some of these settings are hidden or managed by your organization message showing on Privacy Settings page
2020-04-13T18:12:20+00:00
When In Settings>Privacyonly under Windows permissions>diagnostics&feedback and App permissions>Camera do I get ***Some of these settings are hidden or managed by your organization.**I am the only one using this laptop and am shown as administrator.  How can I resolve this issue.  I have exhausted all supposed cures suggested when I search that topic.
****Original title:*Privacy settings***
2020-11-10T00:11:48+00:00
I finally resolved the problem I was having today, involving using the Local Group Policy Editor.  As far as I understand, this is available on Windows 10 Pro, not the Home edition.  Hopefully this will help a few of you.
  • Press Windows key + R to open the 'Run' window.  Type gpedit.msc and press enter.
  • Under Computer Configuration, expand Administrative Templates, then expand Windows Components.
  • Click on App Privacy.  Double-click on the relevant issue, e,g,. if you cannot use your webcam, double-click on 'Let Windows apps access the camera'.
  • On the left under Options, there should be a 'Default for all apps' setting.  In my case this was set to 'Force Deny'.  Change this to 'User is in control', then click OK at the bottom.
  • Click on the Start button, click Settings, then click Privacy.  Hopefully the relevant permission button is no longer greyed out.
You are correct.  The group policy editor is not available in the Home version.
Pro users has other tools as well to fix this. Like system center.
Home users can reset policies by using powershell commands. Pro users can do this as well.
The group policy editor is just a tool that uses the cmd/powershell commands. (Why those tools are not in win 10, I dont understand)
Microsoft released 2 days ago problems in 20H2 with exectly this.
Resetting the PC does work. But only because you reset your policies with that. Thats like buying a new car when you get a flat tire ;).
Here is how you fix the problem of "managed" when your PC IS NOT MANAGED!!! (Some are).
1. Open a powershell or cmd windows (With Admin rights)How to open a cmd or powershell windows.- Click start - Find Windows Powershell folder in the application tree.
  • RIGHT CLICK on the Windows powershell that only say powershell (Not Powershell ISE, x86).
2. Choose open with admin rights.
3. Copy all these commands. And paste them into the powershell
reg delete "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies" /f
reg delete "HKCU\Software\Microsoft\WindowsSelfHost" /f
reg delete "HKCU\Software\Policies" /f
reg delete "HKLM\Software\Microsoft\Policies" /f
reg delete "HKLM\Software\Microsoft\Windows\CurrentVersion\Policies" /f
reg delete "HKLM\Software\Microsoft\Windows\CurrentVersion\WindowsStore\WindowsUpdate" /f
reg delete "HKLM\Software\Microsoft\WindowsSelfHost" /f
reg delete "HKLM\Software\Policies" /f
reg delete "HKLM\Software\WOW6432Node\Microsoft\Policies" /f
reg delete "HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Policies" /f
reg delete "HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\WindowsStore\WindowsUpdate" /f
4. Reboot your system. <---skip this and it does not work
Check the setting that had "managed by" in yellow text. If its gone = fixed and its policies you change with a tool that creates a registry mix that Microsoft yet have to fix.
If you are still "managed", then I suggest Malware removal operation. Then contact Microsoft support. They will help you.
131 additional answers
    2020-10-11T21:32:45+00:00
    I am in that same boat with you. I thought that if I could make myself the administrator each time I wanted to change the access to each of these permissions that it would allow me to fix them. Unfortunately the reply that I received was on how to eliminate the emotions in my text then make myself the administrator  and on another reply I was told that I should not lash out while asking for assistance then read a book on how Microsoft works.
    https://answers.microsoft.com/en-us/windows/forum/windows\_10-other\_settings/why-am-i-not-the-administrator/1a6d3594-90a6-4a56-8de0-0ed4b32ac95e?tab=AllReplies#tabs
    2020-10-12T03:41:34+00:00
    Are you serious? You rcvd a response that included a hand slap comment about not lashing out when asking for help? That is the most absurd thing I've heard to date! I recently tried creating a new or local acct to see if the same issue would occur, yes the same issue occured however differently in that some of the settings blocked on my original admin acct were not the same ones blocked on the newly made acct. In addition, I went in thru the cmd prompt to ensure an administrator acct was active, which this in turn gave me a 3rd acct to test my issues upon, well again the same yet different issue is still present.
    Unfortunately, microsoft has failed me and it seems thousands of other customers effortlessly. I found dialogue that pertained to my very issue back in 2016 and even later than that. It grately showed me just how little their support team cares for its users. If you ever are able to come across an actual resolve plz let me know! I shall do the same.
    I may have to reset my computer which wont be an easy task and one I've been trying to avoid. :(
    2020-10-12T03:44:14+00:00
    Did you ever find an absolute resolve to this issue? I am suffering the same fate.
    2020-10-12T19:23:49+00:00
    I did a system restore keeping my files. Twice.
    Now works perfectly.
