Some of these settings are hidden or managed by your organization message showing on Privacy Settings page
2020-04-13T18:12:20+00:00
When In Settings>Privacyonly under Windows permissions>diagnostics&feedback and App permissions>Camera do I get ***Some of these settings are hidden or managed by your organization.**I am the only one using this laptop and am shown as administrator.  How can I resolve this issue.  I have exhausted all supposed cures suggested when I search that topic.
****Original title:*Privacy settings***
2020-11-10T00:11:48+00:00
I finally resolved the problem I was having today, involving using the Local Group Policy Editor.  As far as I understand, this is available on Windows 10 Pro, not the Home edition.  Hopefully this will help a few of you.
  • Press Windows key + R to open the 'Run' window.  Type gpedit.msc and press enter.
  • Under Computer Configuration, expand Administrative Templates, then expand Windows Components.
  • Click on App Privacy.  Double-click on the relevant issue, e,g,. if you cannot use your webcam, double-click on 'Let Windows apps access the camera'.
  • On the left under Options, there should be a 'Default for all apps' setting.  In my case this was set to 'Force Deny'.  Change this to 'User is in control', then click OK at the bottom.
  • Click on the Start button, click Settings, then click Privacy.  Hopefully the relevant permission button is no longer greyed out.
You are correct.  The group policy editor is not available in the Home version.
Pro users has other tools as well to fix this. Like system center.
Home users can reset policies by using powershell commands. Pro users can do this as well.
The group policy editor is just a tool that uses the cmd/powershell commands. (Why those tools are not in win 10, I dont understand)
Microsoft released 2 days ago problems in 20H2 with exectly this.
Resetting the PC does work. But only because you reset your policies with that. Thats like buying a new car when you get a flat tire ;).
Here is how you fix the problem of "managed" when your PC IS NOT MANAGED!!! (Some are).
1. Open a powershell or cmd windows (With Admin rights)How to open a cmd or powershell windows.- Click start - Find Windows Powershell folder in the application tree.
  • RIGHT CLICK on the Windows powershell that only say powershell (Not Powershell ISE, x86).
2. Choose open with admin rights.
3. Copy all these commands. And paste them into the powershell
reg delete "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies" /f
reg delete "HKCU\Software\Microsoft\WindowsSelfHost" /f
reg delete "HKCU\Software\Policies" /f
reg delete "HKLM\Software\Microsoft\Policies" /f
reg delete "HKLM\Software\Microsoft\Windows\CurrentVersion\Policies" /f
reg delete "HKLM\Software\Microsoft\Windows\CurrentVersion\WindowsStore\WindowsUpdate" /f
reg delete "HKLM\Software\Microsoft\WindowsSelfHost" /f
reg delete "HKLM\Software\Policies" /f
reg delete "HKLM\Software\WOW6432Node\Microsoft\Policies" /f
reg delete "HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Policies" /f
reg delete "HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\WindowsStore\WindowsUpdate" /f
4. Reboot your system. <---skip this and it does not work
Check the setting that had "managed by" in yellow text. If its gone = fixed and its policies you change with a tool that creates a registry mix that Microsoft yet have to fix.
If you are still "managed", then I suggest Malware removal operation. Then contact Microsoft support. They will help you.
131 additional answers
    2020-10-18T11:14:27+00:00
    I recently did that very thing, here is what I was told to do:
    Select “Start” and type “CMD“.
    Right-click “Command Prompt” then choose “Run as administrator“.
    Type: net user administrator/active:yes
    Press “Enter“.
    Replace “yes” with “no” to disable the admin account on the welcome screen.
    _______________________________
    For me it was nothing but a waste of additional time I can't get back bc the problem remained even under that Admin acct only less items were being blocked. If that makes sense.
    Good Luck!
    2020-10-18T15:07:41+00:00
    I also tried CMD in as an Admin (Type “cmd” and then press Ctrl+Shift+Enter to open an administrator Command Prompt.) but it didn't worked either.
    2020-10-18T20:59:29+00:00
    unsubscribe'
    2020-10-19T04:58:24+00:00
    Press “Enter“.
    Good Luck!
    I executed this cmd to activate Administrator ... it now displays as "active" but all functions are still blocked.  No change.
