I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
Audio and video pauses automatically
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
- It happens only when I am playing a video or audio.
- No virus (after scan)
- Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
- Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
- I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
- issues in Windows 10
7. the window also very lag when it happening
- Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
113 additional answers
2020-12-10T01:41:47+00:00 İ have founded that the problem is Amazon Echo device.
When you connected that device to pc over bluetooth, it have permission to control media playback. I could not find a way to fix it.
Also, most of the times, there is lag between video and sound.
I think we both use old model Hp which have slow bluetooth chip on it.
I dont have virus or malware in my pc, as scanners say😂
Still could not find any reasonable solution except disconnecting bluetooth device , Amazon echo dot.
It might be bug of echo dot as well.
2020-12-10T21:48:41+00:00 This is exactly the problem I am facing on my HP laptop as well. Has a solution been found?
2020-12-20T05:14:20+00:00 Facing same issue. Used keyboard test and some undefined key getting pressed. The key for video-play-pause is f10 (without Fn), which when pressed shows as undefined. Did you find a solution for this problem?
2021-01-09T18:05:47+00:00 Its simple its happened to me several time finally I found the problem.
its all about wireless keyboard and mouse. when the battery going to dead in the keyboard and mouse this problem rise at that time just simply replace the batteries.
if the problem still there just check all the batteries of wireless devices.
Thank you.
