I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
Audio and video pauses automatically
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
- It happens only when I am playing a video or audio.
- No virus (after scan)
- Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
- Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
- I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
- issues in Windows 10
7. the window also very lag when it happening
- Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
113 additional answers
2020-11-11T21:55:43+00:00 Hello, i have a dell G5 5500 and i am facing the same problem. My Laptop isnt connected to any bluetooth devices and the bug still happens
2020-11-24T01:08:15+00:00 I am having the same, but, I cant even watch youtube.
Do you use echo dot?
2020-11-29T13:45:43+00:00 I guess everyone are experiencing the same problem as mine, the video player/youtube etc. keep playing and pausing repeatedly and it's annoying.
When i start investigate the problem, i found the root cause (but not the cure), it is the keyboard problem. Somehow, some bug or software repeatedly and randomly "activating" the shortcut key of Media-Play-Pause function. In my case of HP Envy 17 laptop, it is the Fn + F10 shortcut key. You can prove this by checking your keyboard with some online keyboard tester. Apart from the media play/pause problem, i guess this also explain the other problem i occasionally experience: unable to type Capital letter for certain alphabeit (eg. Shift + a; Shift + k etc.)
I'm not sure how my laptop got this problem but it starts to happens few days ago.
I have done all the virus scan, driver update, etc etc but still can't solve this problem. So I suspect it could be the recent window update which has crashed with HP shortcut key.
Anyone here can help develop a cure would be great.
P/S: I haven't tried the keytweak solution yet, to disable some shortcut key. If this solution works then I will update you guys.
2020-12-09T19:29:06+00:00 I am experiencing the same problem. Just started. I even reinstalled Chrome. After reading through these pages, I realized it started after I connected my echo speaker to computer over Bluetooth. I turn off Bluetooth and pause works again. I still want to use my speaker, what is the fix??
