I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
Audio and video pauses automatically
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
- It happens only when I am playing a video or audio.
- No virus (after scan)
- Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
- Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
- I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
- issues in Windows 10
7. the window also very lag when it happening
- Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
113 additional answers
2020-09-03T20:02:38+00:00 I have also the same issue
2020-09-04T19:58:04+00:00 hello sir ,
iam facing the same problem videos and mp3 are getting pause and play automatically i had done unistalling keyboard drivers and graphics driver even recovering and resetting windows but failed can you suggest how to fix this problem
i have HP gaming pavillion laptop
2020-09-15T20:03:45+00:00 Hello, I have the issue, try to press shift when your media starts pausing as a temporary solution.
2020-09-16T16:45:18+00:00 Hi is your issue solved?
I am also facing same issue. Media (song or video) keeps on auto Play pause in every player. Youtube or vlc or windows media player.
I have updated all drivers and updated windows also.
Also if i disable laptop keyboard and use external usb keyboard then issue doesn't happen. Some issue with laptop keyboard but spacebar key is working fine.
This is really troubling me.
