Audio and video pauses automatically
2020-04-01T19:36:23+00:00
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
  1. It happens only when I am playing a video or audio.
  2. No virus (after scan)
  3. Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
  4. Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
  5. I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
  6. issues in Windows 10
7. the window also very lag when it happening
  1. Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
2020-09-17T07:01:58+00:00
I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
113 additional answers
    2021-09-21T06:45:00+00:00
    So i got fed up and removed Windows and intalled linux instead. In Ubuntu initially i faced the same issue but linux gives you more options to diagnose the issue. I noticed a PLAY_PAUSE key was getting pressed. In Ubuntu the mousepad worked but keyboard stopped working. Here is the problem.
    But after a a few Ubuntu upgrades the issue was gone.
    2021-09-22T17:51:38+00:00
    vlc media player and some extra issue in this pc
    2021-09-23T13:35:23+00:00
    • After update and restart work for me.. Even If your PC up-to-date, Restart when this problem occurred .
    • Disable your audio driver, then enable after Restart.
    • Remove All Bluetooth headsets pair from device and Restart it
    2021-10-19T18:34:07+00:00
    Just some extra steps in my case
    go to
    Step 1
    control panel > sound settings > Disable all the Audio device except the current sound device you are using (In my case it is wireless headphone)
    Step 2
    Now open the settings of active audio device and select all the sound enhancement options
    Also select all the exclusive mode in advance option
    Viola ! now the problem solved 😊😊
