Audio and video pauses automatically
2020-04-01T19:36:23+00:00
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
  1. It happens only when I am playing a video or audio.
  2. No virus (after scan)
  3. Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
  4. Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
  5. I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
  6. issues in Windows 10
7. the window also very lag when it happening
  1. Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
2020-09-17T07:01:58+00:00
I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
113 additional answers
    2021-08-12T18:20:50+00:00
    I am also facing the same issue, if anyone find solution, Please mention it here.
    Thanks.
    2021-08-28T05:18:32+00:00
    Hi Ajay!
    I'm also facing same issue in My NUC. i also tried in WINDOWS 11 Pro but the issues is still existed. Please if anyone find any solution keep me posted. Thank you.
    2021-08-28T05:23:25+00:00
    Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).1. It happens only when I am playing a video or audio.2. No virus (after scan)3. Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)4. Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)5. I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key. 6. issues in Windows 10
    7. the window also very lag when it happening 8. Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
    Hi KSTang!
    did your issue fixed? if it is, could you please tell the solution. I'm also facing the same issue in my NUC.
  4. Deleted
