I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
Audio and video pauses automatically
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
- It happens only when I am playing a video or audio.
- No virus (after scan)
- Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
- Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
- I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
- issues in Windows 10
7. the window also very lag when it happening
- Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
113 additional answers
2021-06-12T17:22:24+00:00 Currently facing exactly same issue , Had you found any solution ? Please Let me know.....
2021-06-17T13:23:54+00:00 Not yet buddy, but freuqency of its occurence has reduced after many updates. Occurs very rarely now. Also when scrolling in Device manager I found a synaptics device (which is already present in mice and pointing devices section) installed in the system devices section. I disable it and noticed some improvement. But I believe it's a OS issue as so many people are facing it. Hoping it would get solved in Windows 11.
2021-06-22T06:27:38+00:00 I turned Bluetooth off and it immediately fixed the problem, I was using xbox one controller to navigate kodi. I'll be going back to using Logitech wireless mouse. Hope this helps
2021-07-21T15:48:18+00:00 Thanks. In my case the problem was that my wife was using a bluetooth speaker and my computer was connected. When she played it then she would pause the video for me. It took me a while to figure it out because the speaker was too far from my computer.
