Audio and video pauses automatically
2020-04-01T19:36:23+00:00
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
  1. It happens only when I am playing a video or audio.
  2. No virus (after scan)
  3. Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
  4. Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
  5. I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
  6. issues in Windows 10
7. the window also very lag when it happening
  1. Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
2020-09-17T07:01:58+00:00
I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
113 additional answers
    2021-01-29T17:58:35+00:00
    Product name : HP Laptop 15-bw0xx
    Same model  **** (HP Laptop 15-bw0xx) & same problem
    No bluetooth & no external devices.
    2021-01-30T16:33:00+00:00
    I had the same issue and found someone on a forum talk about his Alexa interfering and causing this issue. I then realized I had recently connected a Denon 150 Bluetooth speaker (though wasn;t using it). After disconnecting the issue didn't appear anymore.
    So I suggest to check Bluetooth or other (wireless) devices that can remotely control audio/video settings.
    2021-01-30T18:33:24+00:00
    Nothing in my case. I have never turned Bluetooth on, so no idea how to solve it
    2021-02-07T17:29:41+00:00
    Hello Kishan are you facing the same issue still? I have the same problem
