I had the same issue and it is solved after i disconnected my Bluetooth Speaker from Denon.
Audio and video pauses automatically
Audio and video pause automatically (and sometimes pause and play) only when I use an internal (Youtube, google) or 3rd party software (windows media player, VLC, films &TVs ).
- It happens only when I am playing a video or audio.
- No virus (after scan)
- Since the spacebar key is usually associated with play & pause, I tried typing something in MS word. I did not see any auto space being generated between 2 letters. (tested for 5 mins)
- Autoplay and pause (sometimes just pause) occur maybe after 20 seconds. (it is random)
- I can actually see the virtual pause and play button is toggled. (no other error message is shown, it happens as if I am physically pressing the spacebar key.
- issues in Windows 10
7. the window also very lag when it happening
- Driver issues? Which driver is it? Any suggestions or experiences? Please share your thoughts.
113 additional answers
2021-01-09T19:00:35+00:00 Thank you for the reply. It has been awhile since I have changed batteries.
I did find a work around also, not a fix. If you put video on mute and then pause, it will start once again but this time when you pause, it stays paused.
2021-01-11T14:19:02+00:00 I don't use a wireless keyboard or mouse.
Further the problem seemed to have disappeared on its own.
It seems like a bad update. Just wait it out... the update will happen.
2021-01-13T14:03:59+00:00 I have a Denon Home 150 speaker connected to my computer through Bluetooth. I'll try disconnecting that. All of my videos have been pausing recently and it's been maddening. I have a Dell XPS-15-7590 laptop with Windows 10. All drivers and updates applied.
2021-01-13T17:02:12+00:00 I disconnected my Denon Home 150 speakers from Bluetooth and now I can stream videos without pauses happening after about 30 seconds. Thanks A. Lozeman for the tip.
Any idea why that was happening? Seems odd that a Bluetooth connection would do that.
