Bluescreen when opening Netflix SYSTEM_THREAD_EXCEPTION_NOT_HANDLED - win10 1909
2020-04-06T20:18:46+00:00
I can run stuff all day (AWS/Vbox/Games), but as soon as I open netflix, machine blue screens with stop code : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
in dxgmms2.sys
its the netflix windows app - I think when I press play it happens, probably happened 6-7 times now.  Quite consistent.
After a reboot, its fine.  I have not been able to cause a bluescreen doing other things.
Winver : 1909 18363.720
GTX 1070ti
I9-9900
Can anyone help?
MEMORY.DMP and msinfo32 here: (i hope)
https://1drv.ms/u/s!AojoZMyTZ1lwgZFZ52vZhGF\_uqKL6w?e=EmJ87X
Im not used to windbg with crashes, snippets from a minidump
EXCEPTION_RECORD:  ffffb10e39fd74d8 -- (.exr 0xffffb10e39fd74d8)
ExceptionAddress: fffff8067a700300 (dxgmms2!VIDMM_SEGMENT::IsMovableResourceCB)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: 00000000000001f8
Attempt to read from address 00000000000001f8PROCESS_NAME:  System
READ_ADDRESS: fffff806601733b8: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
fffff8066002a3c8: Unable to get Flags value from nt!KdVersionBlock
unable to get nt!MmSpecialPagesInUse
 00000000000001f8
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.2: kd> k
 # Child-SP          RetAddr           Call Site
00 ffffb10e`39fd64b8 fffff806`5fddb416 nt!KeBugCheckEx
01 ffffb10e`39fd64c0 fffff806`5fd9d369 nt!PspSystemThreadStartup$filt$0+0x44
02 ffffb10e`39fd6500 fffff806`5fdcb1af nt!_C_specific_handler+0xa9
03 ffffb10e`39fd6570 fffff806`5fcfa2d5 nt!RtlpExecuteHandlerForException+0xf
04 ffffb10e`39fd65a0 fffff806`5fcfe86e nt!RtlDispatchException+0x4a5
05 ffffb10e`39fd6cf0 fffff806`5fdd431d nt!KiDispatchException+0x16e
06 ffffb10e`39fd73a0 fffff806`5fdd0505 nt!KiExceptionDispatch+0x11d
07 ffffb10e`39fd7580 fffff806`7a700300 nt!KiPageFault+0x445
08 ffffb10e`39fd7718 fffff806`7a70830d dxgmms2!VIDMM_SEGMENT::IsMovableResourceCB
09 ffffb10e`39fd7720 fffff806`7a6fdc09 dxgmms2!VIDMM_LINEAR_POOL::DefragmentRange+0xf5
0a ffffb10e`39fd7790 fffff806`7a6eb440 dxgmms2!VIDMM_MEMORY_SEGMENT::Defragment+0xa9
0b ffffb10e`39fd7890 fffff806`7a6c88b0 dxgmms2!VIDMM_GLOBAL::Defragment+0x148
0c ffffb10e`39fd78e0 fffff806`7a6c6ee9 dxgmms2!VIDMM_WORKER_THREAD::Run+0x19b0
0d ffffb10e`39fd7ae0 fffff806`5fc6bce5 dxgmms2!VidMmWorkerThreadProc+0x9
0e ffffb10e`39fd7b10 fffff806`5fdc99ca nt!PspSystemThreadStartup+0x55
0f ffffb10e`39fd7b60 00000000`00000000 nt!KiStartSystemThread+0x2aI am even more lost in this new windbg :>
2020-05-09T21:58:49+00:00
Like so many people I experienced the Blue Screen with the Netflix App. Everything else was running fine.
I noticed it was only happening after a cold boot of the PC.
If I immediately restarted the PC the Netflix App would run fine.
Recently I solved an other problem with my PC where on cold boot it would sometimes not fully turn on ( the screen would remain dark).
This was solved by changing a setting in the Windows control panel:
under Power Options/ System settings
disable "turn on fast startup".
Since I disabled this I also did not get the Blue Screen in the Netflix App anymore.
Worth a try perhaps.
Hardware
CPU AMD Ryzen 9 3950X
GPU NVIDIA GeForce GTX 1080 Ti
52 additional answers
    2020-06-02T16:26:02+00:00
    I use Vbox all the time too
    2020-06-02T16:18:00+00:00
    Not in my case, I can't even install it yet on my computer. I've been trying to think and I didn't change nor install/update anything on my PC for a while so I don't really understand what's going on this time.
    2020-06-02T14:38:08+00:00
    Did y'all do the May Microsoft update?  Microsoft has announced it has plagued with all kinds of problems.
    2020-06-02T12:20:14+00:00
    Me too. Currently I have to avoid netflix on my computer. I would be grateful for a solution for this problem.
    This is really frustrating. Really hope they come up with a solution soon. I usually watch Netflix on my pc because the app supports 4K playback,. But right now, I have to settle for the Google Chrome version, which works fine but at a 720p playback, and drop frames every 10 seconds.
