I figured it out. The web site to access the Bitlocker recovery keys has changed. Go to https://onedrive.live.com/recoverykey.
How do I get BitLocker recovery key with my Key ID
<Locked>
Good afternoon,
My laptop Dell Inspiron suddenly crushed - after restarting it reads that the harddrive is not installed. It is asking for BitLocker Recovery key and below it provides 8 digits of Key ID. I never heard of BitLocker and I tried to access it through my Microsoft account where it says it's not there. Is there any way how can I recover the BitLocker Recovery key using the 8 digits of Key ID? Please help!
Hi Martina -
This is Orlando, an Independent Advisor and an expert with Windows 10.
I understand that you're having issues tryin to find your BitLocker Recovery Key and that you only have the 8 Digits Key ID.
BitLocker is a data protection feature that integrates with the operating system and addresses the threats of data theft or exposure from lost, stolen, or inappropriately decommissioned computers. You can find more details about BitLocker on this link: https://docs.microsoft.com/en-us/windows/securi...
There are several places that your recovery key may be, depending on the choice that was made when activating BitLocker:
- Thru your Microsoft Account
- On a Printout you saved
- On a USB Flash Drive
- It is held by your system administrator
Please refer to this link on finding your BitLocker recovery key in Windows 10.
https://support.microsoft.com/en-gb/help/453047...
The above list are the only way to recover your BitLocker recovery key. You might want to check with the OEM of your computer to check if they are the one who setup the BitLocker of your computer if the above list does not have your recovery key.
Hope this helps, have a good day.
Orlando Q.
Independent Advisor
63 additional answers
2020-04-29T13:52:54+00:00 Thank you Orlando. Unfortunately, it is not stored on my Microsoft account, not the USB and printed documents are lost (laptop is 3 years old). However, I was hoping I can use Key ID - otherwise why would I have Key ID if is it not useful in situations like this one?
Deleted
Deleted
