sfc /scannow WILL NOT function
2020-04-22T21:30:43+00:00
Cmd Prompt > sfc /scannow says Windows Resource Protection could not start the repair service every time I try to use it. What I have tried to do to fix this through reading this site and many others but no luck. This is what I remember trying:
safe mode start
Windows Modules Installer is at manual
DISM /Online /Cleanup-Image /RestoreHealth > operation successfully completed
net start trustedinstaller>successful
chkdsk /r > typed y but it didn't work either
ICACLS C:\Windows\winsxs and restart
all have failed
administrator cmd prompt says C:\WINDOWS\system32 (I have  a 64 though some programs run on 32)
I tried reinstalling 10 with keeping my programs, but the internet is too slow to get it to work even after several days of trying. I can't fresh install even if I had my disk with me. Many of my programs can't be replaced well not by me.
Have  windows 10 but updates always fail many, many, many times if they going through at all.
I need my pc working properly and something is definitely wrong with it. I need the scan and repair to work.
If someone can help me I would really appreciate the kindness.
2020-05-13T07:55:26+00:00
(1) You don't seem to use the Downloads folder. I guess your way is OK.
(2) I don't like that bugcheck. Do you get a lot of them? Those are blue screen errors. There are many threads on bugchecks that are really sad to look at. They end up checking various hardware components one after the other, swapping RAM chips, installing fans & blowing out dust bunnies. But it could just be software as well.
(3) OS Build 17763.557 was 25 quality updates ago. That's pretty far back...!...
https://support.microsoft.com/en-us/help/4503327
June 11, 2019—KB4503327 (OS Build 17763.557)
Not sure what to suggest. Need to hit the sack.
2020-05-20T04:08:09+00:00
Affinity Designer & Affinity Photo have the same hardware specs...
  • Windows-based PC (64 bit) with mouse or equivalent input device
  • DirectX 10-compatible Graphics Cards and above
  • 2GB RAM minimum (4GB RAM recommended)
  • 670MB of available space; more during installation
  • 1280x768 display size or better
And your HP Pavilion 21-h013w can handle that. And you said one of them did work fine a while. (You got the other only after problems surfaced). I think specs isn't the problem.
(1) It could be worth a shot to deal with KB4023057 as in that article I posted earlier. It could be the real troublemaker with the services it has given you. Either uninstall or fully disable it. However, other threads indicate it's a monster to deal with. It will come back & never quit trying to upgrade your computer. And it can thwart WUShowHide.
(2) Or do the dual-install I also mentioned earlier & see what happens in that. You'll have a clean 1909 (as well as that buggy 1809). Want fuller instructions?
141 additional answers
    2020-05-28T05:16:26+00:00
    That is my recommendation. It will be the same as before, except at the "choose where to install Windows" screen. This time select each partition one by one & click Delete. When there is only a huge unallocated space remaining, select it & click Next.
    Fingers crossed, but you've the image anyway.
    2020-05-28T19:43:28+00:00
    I've did as suggested, clean install. Running updates for Windows now. I'll wait for those to install before updating store apps or trying to install programs I actually use.
    The only drives showing File Explorer, at the moment, are Local Drive C: and the USB that's still plugged in.
    2020-05-28T20:19:55+00:00
    Sounds wonderful to me. You now have marvelous partitions & just where they belong. Likely, when 2004 comes in, it will mess with the 1909 Recovery partition, possibly shrinking C: to create a new one for 2004. Then, the 1909 Recovery partition will be emptied but left behind. But that will be nowhere near the mess that was before.
    After the updates, do the DISM, SFC, & make an image. Call it "Clean 1909". After you have installed your apps, make one called "1909 with apps". Delete "1909 with 1809" & "Messy 1909" as soon as you feel comfortable all is well in the world without them.
    Keep us informed. Sounds great. You did well & courageously. Overjoyed there was no big mishap.
