sfc /scannow WILL NOT function
2020-04-22T21:30:43+00:00
Cmd Prompt > sfc /scannow says Windows Resource Protection could not start the repair service every time I try to use it. What I have tried to do to fix this through reading this site and many others but no luck. This is what I remember trying:
safe mode start
Windows Modules Installer is at manual
DISM /Online /Cleanup-Image /RestoreHealth > operation successfully completed
net start trustedinstaller>successful
chkdsk /r > typed y but it didn't work either
ICACLS C:\Windows\winsxs and restart
all have failed
administrator cmd prompt says C:\WINDOWS\system32 (I have  a 64 though some programs run on 32)
I tried reinstalling 10 with keeping my programs, but the internet is too slow to get it to work even after several days of trying. I can't fresh install even if I had my disk with me. Many of my programs can't be replaced well not by me.
Have  windows 10 but updates always fail many, many, many times if they going through at all.
I need my pc working properly and something is definitely wrong with it. I need the scan and repair to work.
If someone can help me I would really appreciate the kindness.
2020-05-13T07:55:26+00:00
(1) You don't seem to use the Downloads folder. I guess your way is OK.
(2) I don't like that bugcheck. Do you get a lot of them? Those are blue screen errors. There are many threads on bugchecks that are really sad to look at. They end up checking various hardware components one after the other, swapping RAM chips, installing fans & blowing out dust bunnies. But it could just be software as well.
(3) OS Build 17763.557 was 25 quality updates ago. That's pretty far back...!...
https://support.microsoft.com/en-us/help/4503327
June 11, 2019—KB4503327 (OS Build 17763.557)
Not sure what to suggest. Need to hit the sack.
2020-05-20T04:08:09+00:00
Affinity Designer & Affinity Photo have the same hardware specs...
  • Windows-based PC (64 bit) with mouse or equivalent input device
  • DirectX 10-compatible Graphics Cards and above
  • 2GB RAM minimum (4GB RAM recommended)
  • 670MB of available space; more during installation
  • 1280x768 display size or better
And your HP Pavilion 21-h013w can handle that. And you said one of them did work fine a while. (You got the other only after problems surfaced). I think specs isn't the problem.
(1) It could be worth a shot to deal with KB4023057 as in that article I posted earlier. It could be the real troublemaker with the services it has given you. Either uninstall or fully disable it. However, other threads indicate it's a monster to deal with. It will come back & never quit trying to upgrade your computer. And it can thwart WUShowHide.
(2) Or do the dual-install I also mentioned earlier & see what happens in that. You'll have a clean 1909 (as well as that buggy 1809). Want fuller instructions?
141 additional answers
    2020-05-19T21:21:43+00:00
    1. Jump to image is greyed out and jumped to entry for "C:\PROGRA~3\INTERE~1\INTERE~2.DLL" it restarted autorun
    2. Here's what DISM  /Online  /Cleanup-Image  /ScanHealth says,
    Microsoft Windows [Version 10.0.17763.557]
    (c) 2018 Microsoft Corporation. All rights reserved.
    C:\WINDOWS\system32>DISM  /Online  /Cleanup-Image  /ScanHealth
    Deployment Image Servicing and Management tool
    Version: 10.0.17763.1
    Image Version: 10.0.17763.557
    [==========================100.0%==========================] No component store corruption detected.
    The operation completed successfully.
    I guess that's a good thing but frustrating that it can't fix what's screwy. Sleep well.
    2020-05-20T02:50:23+00:00
    (1) Regarding "C:\PROGRA~3\INTERE~1\INTERE~2.DLL", just right-click & delete it in Autoruns.
    Because ancient DOS could have names only 8 characters long, every file & folder in Windows even today has two names. One is the long name seen in File Explorer. The other is the first 5 or 6 letters of that name followed by a tilde (~) & a number. It wants to be no more than 8 characters long.
    Since we have 3 folders in *C:* that begin "PROGRA", the 3rd one gets the "~3". Do a "DIR  C:\Progra~3" at a Command Prompt, & likely you will see the folders & files of "C:\Programdata" get listed. At one point, you had at least one folder in that one that began "INTERE". The 1st one got the "~1". I think Autoruns is saying INTERE~1 no longer exists -- not just INTERE~2.DLL which used to be in it. Do a "DIR  C:\PROGRA~3\INTERE~1", & it will say "File Not Found" (meaning the folder).
    I say just right-click & delete that entry in Autoruns. No more to do with that that is perfectly safe.
    (2) It is good DISM is fine. Absolutely, it's a shame it won't make SFC work in Windows. Chances are, though, SFC in Windows would have been as ineffectual as SFC offline to fix the current difficulties. That triples the shame!
    2020-05-20T23:21:52+00:00
    Windows Setup Remediations (x64) KB4023057 doesn't show up in  my Settings -> Apps -> Apps & features nor in a Cortana search so maybe I should try the dual-install as you said it seems to be a barnacle (hard to scrape off). Think I'll need some help with the dual-install if you can.
    Thanks again for your help and time.
