sfc /scannow WILL NOT function
2020-04-22T21:30:43+00:00
Cmd Prompt > sfc /scannow says Windows Resource Protection could not start the repair service every time I try to use it. What I have tried to do to fix this through reading this site and many others but no luck. This is what I remember trying:
safe mode start
Windows Modules Installer is at manual
DISM /Online /Cleanup-Image /RestoreHealth > operation successfully completed
net start trustedinstaller>successful
chkdsk /r > typed y but it didn't work either
ICACLS C:\Windows\winsxs and restart
all have failed
administrator cmd prompt says C:\WINDOWS\system32 (I have  a 64 though some programs run on 32)
I tried reinstalling 10 with keeping my programs, but the internet is too slow to get it to work even after several days of trying. I can't fresh install even if I had my disk with me. Many of my programs can't be replaced well not by me.
Have  windows 10 but updates always fail many, many, many times if they going through at all.
I need my pc working properly and something is definitely wrong with it. I need the scan and repair to work.
If someone can help me I would really appreciate the kindness.
2020-05-13T07:55:26+00:00
(1) You don't seem to use the Downloads folder. I guess your way is OK.
(2) I don't like that bugcheck. Do you get a lot of them? Those are blue screen errors. There are many threads on bugchecks that are really sad to look at. They end up checking various hardware components one after the other, swapping RAM chips, installing fans & blowing out dust bunnies. But it could just be software as well.
(3) OS Build 17763.557 was 25 quality updates ago. That's pretty far back...!...
https://support.microsoft.com/en-us/help/4503327
June 11, 2019—KB4503327 (OS Build 17763.557)
Not sure what to suggest. Need to hit the sack.
2020-05-20T04:08:09+00:00
Affinity Designer & Affinity Photo have the same hardware specs...
  • Windows-based PC (64 bit) with mouse or equivalent input device
  • DirectX 10-compatible Graphics Cards and above
  • 2GB RAM minimum (4GB RAM recommended)
  • 670MB of available space; more during installation
  • 1280x768 display size or better
And your HP Pavilion 21-h013w can handle that. And you said one of them did work fine a while. (You got the other only after problems surfaced). I think specs isn't the problem.
(1) It could be worth a shot to deal with KB4023057 as in that article I posted earlier. It could be the real troublemaker with the services it has given you. Either uninstall or fully disable it. However, other threads indicate it's a monster to deal with. It will come back & never quit trying to upgrade your computer. And it can thwart WUShowHide.
(2) Or do the dual-install I also mentioned earlier & see what happens in that. You'll have a clean 1909 (as well as that buggy 1809). Want fuller instructions?
141 additional answers
    2020-05-11T23:53:35+00:00
    2020-05-12T01:43:09+00:00
    At least it came in a pretty little box & asked for your approval. Was it quick? Let's see SetupDiagResults.log.
    2020-05-12T03:08:33+00:00
    Well it was shorter than some other fails.
    Matching Profile found: FindAbruptDownlevelFailure - 55882B1A-DA3E-408A-9076-23B22A0472BD
    SetupDiag version: 1.6.0.0
    System Information:
        Machine Name = MYPC
        Manufacturer = Hewlett-Packard
        Model = 21-h013w
        HostOSArchitecture = x64
        FirmwareType = UEFI
        BiosReleaseDate = 20140616000000.000000+000
        BiosVendor = 80.10
        BiosVersion = 80.10
        HostOSVersion = 10.0.17763
        HostOSBuildString = 17763.1.amd64fre.rs5_release.180914-1434
        TargetOSBuildString = 10.0.18362.770 (19h1_release_svc_prod1.200309-1836)
        HostOSLanguageId =
        HostOSEdition = Core
        RegisteredAV = Windows Defender
        FilterDrivers = FileInfo
        UpgradeStartTime = 5/5/2020 3:31:35 PM
        UpgradeEndTime = 5/5/2020 4:43:01 PM
        UpgradeElapsedTime = 01:11:26
        CV = tFmz9P/b8E2yPqUB
        ReportId = F0D3CCB9-6371-48A0-AE2E-8679485A4EE3
    Error: SetupDiag reports abrupt down-level failure.
    Last Operation: Finalize
    Error: 0x8007007E - 0x50015
    LogEntry: 2020-05-05 16:41:26, Error                 DISM   DISM Driver Manager: PID=18924 TID=20744 Failed trying to load drvstore.dll - CDmiApi::InternalInitialize(hr:0x8007007e)
    Refer to "https://docs.microsoft.com/en-us/windows/desktop/Debug/system-error-codes" for error information.
    Last Setup Phase:
    Phase Name: Pre-Finalize
        Phase Started: 5/5/2020 4:39:25 PM
        Phase Ended: 1/1/0001 12:00:00 AM
        Phase Time Delta: 00:00:00
        Completed Successfully? False
    Last Setup Operation:
    Operation Name: Process Drivers for Migration
        Operation Started: 5/5/2020 4:41:18 PM
        Operation Ended: 1/1/0001 12:00:00 AM
        Operation Time Delta: 0:00:00:00.0000000
    SetupDiag was unable to match to any known failure signatures.
    System Information:
        Machine Name = MYPC
        Model = 21-h013w
        FirmwareType = UEFI
        BiosVendor = 80.10
        BiosVersion = 80.10
        HostOSLanguageId =
        FilterDrivers =
        UpgradeStartTime = 5/11/2020 8:11:14 PM
        UpgradeEndTime = 5/11/2020 8:14:59 PM
        UpgradeElapsedTime = 00:03:45
    System Information:
        Machine Name = MYPC
        Model = 21-h013w
        HostOSArchitecture = 1033
        FirmwareType = UEFI
        BiosVendor = 80.10
        BiosVersion = 80.10
        HostOSLanguageId =
        FilterDrivers =
