sfc /scannow WILL NOT function
2020-04-22T21:30:43+00:00
Cmd Prompt > sfc /scannow says Windows Resource Protection could not start the repair service every time I try to use it. What I have tried to do to fix this through reading this site and many others but no luck. This is what I remember trying:
safe mode start
Windows Modules Installer is at manual
DISM /Online /Cleanup-Image /RestoreHealth > operation successfully completed
net start trustedinstaller>successful
chkdsk /r > typed y but it didn't work either
ICACLS C:\Windows\winsxs and restart
all have failed
administrator cmd prompt says C:\WINDOWS\system32 (I have  a 64 though some programs run on 32)
I tried reinstalling 10 with keeping my programs, but the internet is too slow to get it to work even after several days of trying. I can't fresh install even if I had my disk with me. Many of my programs can't be replaced well not by me.
Have  windows 10 but updates always fail many, many, many times if they going through at all.
I need my pc working properly and something is definitely wrong with it. I need the scan and repair to work.
If someone can help me I would really appreciate the kindness.
2020-05-13T07:55:26+00:00
(1) You don't seem to use the Downloads folder. I guess your way is OK.
(2) I don't like that bugcheck. Do you get a lot of them? Those are blue screen errors. There are many threads on bugchecks that are really sad to look at. They end up checking various hardware components one after the other, swapping RAM chips, installing fans & blowing out dust bunnies. But it could just be software as well.
(3) OS Build 17763.557 was 25 quality updates ago. That's pretty far back...!...
https://support.microsoft.com/en-us/help/4503327
June 11, 2019—KB4503327 (OS Build 17763.557)
Not sure what to suggest. Need to hit the sack.
2020-05-20T04:08:09+00:00
Affinity Designer & Affinity Photo have the same hardware specs...
  • Windows-based PC (64 bit) with mouse or equivalent input device
  • DirectX 10-compatible Graphics Cards and above
  • 2GB RAM minimum (4GB RAM recommended)
  • 670MB of available space; more during installation
  • 1280x768 display size or better
And your HP Pavilion 21-h013w can handle that. And you said one of them did work fine a while. (You got the other only after problems surfaced). I think specs isn't the problem.
(1) It could be worth a shot to deal with KB4023057 as in that article I posted earlier. It could be the real troublemaker with the services it has given you. Either uninstall or fully disable it. However, other threads indicate it's a monster to deal with. It will come back & never quit trying to upgrade your computer. And it can thwart WUShowHide.
(2) Or do the dual-install I also mentioned earlier & see what happens in that. You'll have a clean 1909 (as well as that buggy 1809). Want fuller instructions?
141 additional answers
    2020-05-05T18:15:33+00:00
    Okay got the USB to work and finally the scannow says "Windows Resource Protection did not find any integrity violations". Which is a good thing I suppose, but it means nothing was fixed.
    To clearify what I had done before though I guess it doesn't matter now- I restarted holding shift,(recovery environment) click troubleshoot>Advanced Options>command prompt.. There was a choice of Administrator or my user account. The first time I tried it as administrator - It asks for a password, which I don't have and have tried to fix many times without success, so I went back into google and tried again to find how to get arround or reset it again. I did what is recommended until it says to type new password then it stops letting me type. This has happened everytime I try to reset it in the past. Another suggestion was to just hit enter a couple times and it opens to the prompt, which it does, I then followed your instructions from there.
    A lot of type came up which I thought you'd like to see but it
    wouldn't copy and paste since windows wasn't open I suppose. I tried it again to see if I could get a copy but I couldn't paste it. I tried to run a scannow and got the same message as I said. So I tried it under my account and got the same.
     And the D drive had the Windows and user folders not C so I used D:\
    I tried the same thing while I was in windows and there the C drive has the user and window folders, odd.
    If it's supposed to be C:, sure I'd like to fix it. So many things seems to be messed up and I don't know why. Could it be because this was afactory refurbish? HP said it was wiped clean and reinstalled before I bought it. There's a "Fake Legacy Options"? Something to do with older Bios vs UEFI in newer systems?
    2020-05-05T18:21:18+00:00
    May 5 2020
    update fail
    There were problems installing some updates, but we'll try again later.
    Feature update to Windows 10, version 1909 - Error 0x80246007
    Status: Some updates didn't finish downloading. We'll keep trying. Error code: (0x80246007)
    2019-10 Cumulative Update for .NET Framework 3.5, 4.7.2 and 4.8 for Windows 10 Version 1809 for x64 (KB4524099) - Error 0x80073712
    Status: 2019-10 Cumulative Update for .NET Framework 3.5, 4.7.2 and 4.8 for Windows 10 Version 1809 for x64 (KB4524099) - Error 0x80073712
    Microsoft .NET Framework 4.8 for Windows 10 Version 1809 for x64 (KB4486153) - Error 0x80073712
    Status: Some update files are missing or have problems. We'll try to download the update again later. Error code: (0x80073712)
    2020-05-06T00:14:06+00:00
    Run SetupDiag, & copy/paste the full contents of SetupDiagResults.log into here. Sounds like it will have more to say this time. I hope it didn't take hours to fail this time.
    In the meantime, I'll be answering your prior post. It just might be worthwhile to have C:\ remain C:\ in the update pre-boot environment, which is akin to the recovery environment. Hopefully, curing it in one will cure it in the other. Windows may be getting confused having it switch during the reboot(s) it does to complete a feature install.
