Realtek Audio device Code 10 cannot start and unable to update
2020-03-22T05:55:16+00:00
My headphone and mic jacks on my pc do not work and I have been trying for hours to get my on board sound working. I got the realtek drivers from my board manufacturer and every time I install them I get (Code 10 : Device cannot start.) I have tried updating and I have the newest driver so I am entirely stuck here.
I have tried many different realtek drivers and none work, not even the one supplied by the manufacturer so I would really appreciate if anyone could walk me through how to actually get my sound working.
I have a Z390 Phantom Gaming 4 board and Intel i5 9600K chip.
    2020-04-02T23:31:57+00:00
    (1) That could be a good idea. Afterwards, report the status of these three...
    Onboard HD Audio
    Enable/disable onboard HD audio. Set to Auto to enable onboard HD audio and automatically disable it when a sound card is installed.
    Front Panel
    Enable/disable front panel HD audio.
    Onboard HDMI HD Audio
    Enable audio for the onboard digital outputs.
    Edit:  Well, a reset to defaults in BIOS won't be a problem unless you've switched from UEFI to Legacy mode before installing Windows. You said you haven't done that. Going to Defaults just affects settings you have done.
    But I'm unsure what pulling the CMOS battery will do -- will it restore the factory state BIOS of the computer? Then be prepared to flash it afterward with the latest version from your site.
    (2) I might, though, just before that...
    (a) Replace the Asus VP278 monitor with the one that has no speakers.
    (b) Uninstall...
         both High Definition Audio Controller's under System Devices,
         Asus VP278 under Audio Inputs & Outputs, &
         both of them under Sound, Video & Game Controllers.
    (c) Reboot.
    Good luck.
    2020-04-03T08:45:12+00:00
    Are you using your soundcard as a oscope by chance?
    2020-04-04T23:07:31+00:00
    No I'm not using it for anything like that.
    I removed the CMOS battery and it did reset the bios. Onboard audio, hd audio, and front panel are all enabled for sure after doing this.
    Reinstalled realtek, still nothing happens, same as always. Is there any way at all to use a gaming headset through an external sound card such as my Steinberg CI1? When I tried it before I reset windows it would not recognize the mic, though I did get audio through the headphones. I'm nearly convinced my board is simply defective and would rather try to make my other sound card work but I'm not sure it's possible.
    2020-04-05T02:47:49+00:00
    (1) Sorry to hear the problem remains unresolved. I guess I'm leaning toward a chip failure too. I would upgrade the BIOS, if it has reverted to an earlier version. Your site has version 4.40 dated 2020/1/2. I would rather you get this to work too. Are there hardware tests in your BIOS that I didn't see in the User Manual?
    (2) Here is the Steinberg CI1 site...
    https://www.steinberg.net/en/support/downloads_hardware/downloads_ci1.html
    Steinberg CI1
    Ensure you have the latest driver which is version 2.0.3. What is your gaming headset make & model? Looking at the Steinberg CI1 Operation Manual, it looks like you'd need a headphone mic splitter such as one of these...
    https://www.amazon.com/slp/headphone-mic-splitter/ceuun2nq7wpk4e9
    Amazon's headphone mic splitters
    Good luck, & keep us informed.
    2020-04-05T09:01:30+00:00
    My headset does have a splitter and I tried it in the CI1 with updated drivers before. Audio was fine but couldn't recognize any input devices for some reason. I could try updating the bios but the website warns that it can break a lot of stuff so I was wary of doing it.
    Audio has never, ever registered on this pc without an external card or hdmi monitor even when I first built it. I even took it apart and checked all the connections on the board today and the front panel, etc. It all looked good according to the diagrams in the manual so I really think the board sound was broken from the start but it's hard to say for sure. Gaming head set is LucidSound LS25.
