Lenovo Ideapad S340: Integrated Camera not working after trying F8, LEnovo Vantage and Device Manager changes
2020-03-03T16:05:05+00:00
Hi community. After reading some members having similar issue, I have tried some of the suggested fixes, such as activating camera through F8 (nothing happened), Checking Privacy and Permissions setting in Lenovo Vantage app (all ok), and also in Device Manager I tried Updating Drivers, Disabling/Enabling camera, Un-installing and Re-installing camera.
I have then removed Lenovo Vantage app.
No success. I tried the camera app and Skype, and still getting just a black screen instead of the camera view.
Appreciate any help with this issue.
2021-12-29T20:52:59+00:00
Did EVERY GD thing and finally - the resolution was the BIOS update. Camera is now working. Lenovo is Chinese junk.
106 additional answers
    2021-08-25T15:05:37+00:00
    OMG! You are a lifesaver! I have spent two days scrolling through the internet and so pleased I stumbled across your solution. Hard to believe but it worked! Thank you.
    2021-09-03T03:41:13+00:00
    I faced the same issue and tried all the methods that you have mentioned but the integrated camera didn't work.went to an authorised lenovo centre where they told me that the camera of this model is faulty and many people have been facing the same issue,so I just started using a USB webcam.
    2021-09-10T17:05:08+00:00
    Hello Ricardo Dias,
    i really wanna thank to you and all the people who contributed here their suggestions!
    i was also having exact the same isssue with my Lenovo S340 14 Laptop for two three days, i tried everything like everything, but no success. i uninstalled the integrated camera driver und reinstalled it, F8 button was on, it was allowed by windows security to turn camera on, windows update was latest, Lenovo Vantage wasnt helpfull in my case, cause, usually if you go into Lenovo Vantage , you will see there audio and camera functions in settings but in my case if i went into the app, the camera function was just gone, it disappeared, i also un and reinstalled the lenovo Vantage so that it will be fixed, but it was not. and i did many other things with wondows system and i couldnt fix it, and i called support team and they also couldnt.
    after reading your valuable suggestions, i finally fixed it, what i did is just unistalled the latest driver suggested by windows and installed the old one from 2019 which you left here as a link, thanks a lot!
    cheersss!!!
    2021-09-10T17:10:22+00:00
    hello,
    just try to install the old driver
    i hope this will help
