Did EVERY GD thing and finally - the resolution was the BIOS update. Camera is now working. Lenovo is Chinese junk.
Lenovo Ideapad S340: Integrated Camera not working after trying F8, LEnovo Vantage and Device Manager changes
Hi community. After reading some members having similar issue, I have tried some of the suggested fixes, such as activating camera through F8 (nothing happened), Checking Privacy and Permissions setting in Lenovo Vantage app (all ok), and also in Device Manager I tried Updating Drivers, Disabling/Enabling camera, Un-installing and Re-installing camera.
I have then removed Lenovo Vantage app.
No success. I tried the camera app and Skype, and still getting just a black screen instead of the camera view.
Appreciate any help with this issue.
106 additional answers
2021-03-03T00:32:49+00:00 So I have had same issues as everyone posted and have tried to fix using all methods mentioned.
What I believe, is that it is a hardware issue.
I read someone had loose cables in their built-in camera. They pressed on the camera or area around camera gently and it turned on.
I turned on camera and got the no hardware detected fault code. I pressed gently around my camera and the white light turned on and so did my camera. It must have come loose from opening and closing laptop maybe grabbing it from near camera.
This solved my issues, hope this helps.
-Roman
2021-03-03T01:59:28+00:00 Mine turned out to be a similar issue and I had forgotten to post. There is a switch that goes over the camera and I must have inadvertently turned turned off. During a Windows update it did stop working again, but I went to Lenovo Vantage and found the Camera & Display setting and turned off the Camera Privacy Mode, which I hope I don't have to do everything there is an update.
2021-03-04T12:29:16+00:00 I am having Lenovo S340 with the same camera. So I called a Lenovo Engineer, one breaks my screen so the other came and fixed my screen and camera too. The camera cable which is pre-built in the laptop has more than 3 Joints, so sometimes these joints tend to make cause such problems. So the engineer changed the cable which had 2 or 3 joints ( I don't remember), and the camera is working perfectly and flawlessly without any issues in one month. So I request you all to request the customer support to change the cable.
Thanks and Regards
Tushar
(Not a Lenovo Guy)(Press Thanks)(Any other fix, reply to this comment)
2021-03-09T14:26:09+00:00 Thanks Tushar!.
regards.
