Error 0X800701B1 - how to fix it?
2019-11-03T04:18:53+00:00
Having problem with external hdd drive and after scanned and fixed, problem keeps appearing. Furthermore another error message when transferring files Error 0X800701B1. Kindly advise how to fix it.
    2021-04-09T00:07:46+00:00
    Never being a XBox user... I don't have answer. My guess is recent Windows 10 seems to access disk drive differently. Specific disk controller and/or USB controller (hw chip or sw driver) may get stuck under occasion.
    2021-04-28T00:29:54+00:00
    how to fix    0x8000x7016a error
    2021-05-09T06:46:20+00:00
    How can I fix this problem? It repeats itself over and over again. Error 0X800701B1 Greg
    2021-05-11T12:47:21+00:00
    If people read through this whole thread they will understand that the problems are with a secondary hard disk controller.  My problem was with a secondary hard drive controller with a Marvell chip.  I swapped out the controller and my errors disappeared.  I'm not sure what you can do if your problem is with a USB drive, but the issue is probably tied to the controller and not the drive itself or Windows software or drivers.  I recently took a look at my Marvell controller that I had previously removed and found that some of the dips were sent incorrectly, but I am not going to reinstall it to see if it works OK if I set the dips correctly.  My findings have been that the secondary hard drive controller, especially if it has a Marvell controller chip, is the cause of these errors.  If you have a secondary hard drive controller, replace it or if you have a USB drive, move it to a different USB port.
  5. Deleted
