Another thing i did was run it in RAID mode over AHCI. That might help. Try it out before anything.
System wide stuttering in latest install of windows after a fresh install
I recently built a new computer and installed windows 10 on it. After I the first hour or so I started experiencing a system-wide stuttering. It happens while I play games, it happens while I watch Netflix, and it is happening while I type this. It makes any kind of media playback worthless. The audio and video are both effected during the stutters which last less than a second but occur about every 1-2 seconds. I have fully updated all my drivers including the bios, altered power settings, and other things mentioned in some of the older posts on this topic. I've included this snapshot of my setup since it seems to be a popular request on the older forums at least. I am wondering if there are new solutions since none of the ones that have been mentioned in the past have been helpful.
Thanks in advance!
60 additional answers
2020-01-05T17:54:14+00:00 The stutter, is it just your display or does sound also get affected?
For instance, you are watching a movie and it freezes, repeats sounds and then goes on?
2020-01-05T18:13:14+00:00 The stutter effects everything as far as I can tell: audio, video, simple windows animations, in every program. Im away from my computer but i can post a video when i get back. I have seen a few other videos of people having the same problem. Nothing ever crashes or stops running, the whole computer stutters also, not just the program that is open.
2020-01-05T20:20:02+00:00 Sure I would love to see a video.
2020-01-05T20:35:57+00:00 https://photos.app.goo.gl/BTizNXJ1LRopoTfA7
I couldnt find a way to upload the video itself, but here is a link to the video. There is a continuous lag and thats not what im having troubles with. If you listen carefully you can hear the stuttering which is a bit more random. The video is also effected a little bit i may be hard to see since there isnt much movement. I hope this helps.
