The store is now closed for win 8.1. No it wont reopen. They make you upgrade to win10 to keep your 8.i phone in use. If you want all of your apps back you MUST do the over the cable upgrade to win10. I know it SUCKS but thats the only choice. If you do not do this now you might not have a chance after 12/16 so THINK long and hard and know we are in the same boat. I chose to do it and the over the cable upgrade to win 10 worked and I got all of my apps back plus last win 10 update for 11/12/10. If you need info about the OTC upgrade see the posts about it. You have to have a laptop and a usb cable and internet. You download the MS OTG and run it with your Lumia connected. Good luck everyone. THE STORE FOR WIN 8.1 IS DEAD! NO MORE!
how to fix error code 80070057 from store in windows phone 8.1 update
Hello, I'm using Nokia Lumia 530 model with windows phone 8.1 update and OS version is 8.10.14234.375. I am unable to sign in my existing Microsoft account because store contains error code 80070057 continuously so I'm unable to download any app from store in windows phone device. So please solve my problem urgently. Please help me. Please help.
Deleted
2019-11-26T20:22:47+00:00 -
2019-11-26T21:07:14+00:00 I have the same problem with my lumia 640 LTE code error c101a006
Deleted
2019-11-27T09:56:55+00:00 I have got the same problem
