Wireless bluetooth earphones keep disconnecting...
2019-11-27T12:53:47+00:00
I bought Realme buds wireless bluetooth earbuds recently. I started using them with my phone and it worked just fine. But when I used it with my laptop (Asus FX570UD) it works for sometime and then automatically disconnects and the same problem persists when I reconnect it again. I tried troubleshooting but it is of no use. I need help with why it keeps disconnecting frequently??
2020-01-30T06:40:45+00:00
no, it didn't work for me. because when you uninstall Bluetooth driver , windows automatically install a new one.
Windows will do that automatically as when you uninstall in the device manager, the driver has not been removed from the root. I faced a similar problem as Realtek driver used to reinstall after rebooting. So used a third part utility to uninstall: https://www.driverscape.com/download.
Driverscape utility worked for me to uninstall the system Realtek bluetooth driver from root. After I rebooted, windows installed the Microsoft Generic bluetooth adapter, which works perfectly with realme buds wireless. Try this method to uninstall and let me know if it worked for you.
63 additional answers
    2020-02-24T18:29:10+00:00
    Have you tried unchecking the box in the Bluetooth power management (devicemgr) that says "allow the computer to shut off this device to save power" or something to that effect?
    2020-02-25T11:51:48+00:00
    No It didn't work for me.
    2020-03-31T21:59:30+00:00
    hey, i had the same problem with my realme buds wireless. i tried everything but this issue just didn't solved. finally i was messing with some settings and finally i found the solution.
    go into, sound settings >  manage sound devices > there you will found two realme buds device options, DISABLE the hands free AG option and done. now they work fine.
    hope this works for you too.
    2020-04-28T05:41:25+00:00
    Same Problem.......
    Anyone find the Solution??
