Print Management Console Script error?
2019-10-03T13:40:53+00:00
For the last couple of days I get this error when accessing printer properties or just selecting a printer in the print management console:
Anyone else having this issue?  Selecting yes or no has the same effect, i.e., none that I can tell.
I manage several print servers from the management console so looking in my workstation devices and printers isn't the answer. (seemed to be the answer of choice from a similar thread I saw and isn't applicable)
2020-01-29T13:28:52+00:00
This update fixes the issue for current versions of Windows 10 (1903, 1909).
https://support.microsoft.com/en-us/help/4532695/windows-10-update-kb4532695
I just applied this and the Print Mgmt. Console is working again.
69 additional answers
    2019-11-05T21:18:51+00:00
    So far, the 'fix' seems to be to stop using extended view.   <sigh>
    Yea that's ridiculous.
    2019-11-05T21:25:33+00:00
    I've posted this topic in Spiceworks as well. There are a number of IT Pros working on this to find the solution. Haven't heard from Microsoft yet.
    2019-11-06T03:30:50+00:00
    Link us?
    2019-12-10T16:05:05+00:00
    I uninstalled KB4524570 and the script error went away........................Problem solved.
