Print Management Console Script error?
2019-10-03T13:40:53+00:00
For the last couple of days I get this error when accessing printer properties or just selecting a printer in the print management console:
Anyone else having this issue?  Selecting yes or no has the same effect, i.e., none that I can tell.
I manage several print servers from the management console so looking in my workstation devices and printers isn't the answer. (seemed to be the answer of choice from a similar thread I saw and isn't applicable)
2020-01-29T13:28:52+00:00
This update fixes the issue for current versions of Windows 10 (1903, 1909).
https://support.microsoft.com/en-us/help/4532695/windows-10-update-kb4532695
I just applied this and the Print Mgmt. Console is working again.
69 additional answers
    2019-10-18T18:28:38+00:00
    It *might* be KB4517389 for 1903? Sorry, I blocked the 1903 updates in my environment until they hit the semi-annual channel. I'll look to see if I have the ISO and spin up a VM if I do.
    2019-10-18T18:53:41+00:00
    I just removed KB4517389 on 1903 and rebooted.  Unfortunately, it did not resolve the issue.
    2019-10-18T18:59:44+00:00
    This is like fishing!
    2019-10-18T19:30:30+00:00
    I just installed 1903 v2 into a VM and before any updates it was broken! Gah! It had these updates installed:
    I wish I had checked BEFORE I started installing update (that top one finished before I could check Print Management) but it looks like that KB is for secure boot stuff. Googling the installed KBs showed that KB4515384 did similar stuff to the KB I removed to fix the issue in 1809. After rebooting KB4515384 was gone and KB4517389 was in it's place. So I uninstalled KB4517389, did a reboot, tried to uninstall KB4515384, but got the error "Update for Microsoft Windows (KB4515384) is required by your computer and cannot be uninstalled. Well, ****. I *really* miss the old update system where you could select the updates you wanted, regardless of it's importance level. I'm downloading a 1903 V1 ISO, let's see how that goes.
