Print Management Console Script error?
2019-10-03T13:40:53+00:00
For the last couple of days I get this error when accessing printer properties or just selecting a printer in the print management console:
Anyone else having this issue?  Selecting yes or no has the same effect, i.e., none that I can tell.
I manage several print servers from the management console so looking in my workstation devices and printers isn't the answer. (seemed to be the answer of choice from a similar thread I saw and isn't applicable)
2020-01-29T13:28:52+00:00
This update fixes the issue for current versions of Windows 10 (1903, 1909).
https://support.microsoft.com/en-us/help/4532695/windows-10-update-kb4532695
I just applied this and the Print Mgmt. Console is working again.
69 additional answers
    2019-10-18T17:42:00+00:00
    I fixed it! This worked for me at least, but installing KB4519338 on a Windows 10 Pro 1809 VM broke the print management, then when I uninstalled the update from the VM, print management started working again. To uninstall it, open control panel -> programs -> programs and features -> installed updates, right click it, choose uninstall. It occurs to me that after doing that update it took the Print Management snap in a long time to list all the printers, too. My guess is that it uses Internet Explorer as it's guts to show everything, and KB4519338 made some big security changes for IE and Edge. I'll be removing this update from my workstation as well.
    2019-10-18T18:00:32+00:00
    I don't have that update installed on my PC, however I'm sure one of my Microsoft Updates is responsible. Thanks NinjaGeoff
    2019-10-18T18:12:58+00:00
    I don't have the update installed but it's for 1809.  I have 1903.
    2019-10-18T18:19:01+00:00
    I have 1903 installed as well.
