Print Management Console Script error?
2019-10-03T13:40:53+00:00
For the last couple of days I get this error when accessing printer properties or just selecting a printer in the print management console:
Anyone else having this issue?  Selecting yes or no has the same effect, i.e., none that I can tell.
I manage several print servers from the management console so looking in my workstation devices and printers isn't the answer. (seemed to be the answer of choice from a similar thread I saw and isn't applicable)
2020-01-29T13:28:52+00:00
This update fixes the issue for current versions of Windows 10 (1903, 1909).
https://support.microsoft.com/en-us/help/4532695/windows-10-update-kb4532695
I just applied this and the Print Mgmt. Console is working again.
69 additional answers
    2020-01-24T20:46:32+00:00
    Does this work with the  KB4534273 installed?
    2020-01-27T07:13:17+00:00
    Ladies and gentlemen,
    There is no solution, and it is not professional by Microsoft. It is impossible to manage such a large number of printers in such a way that the fault appeared only after an upgrade to 1903.
    Are they aware of the issue?
    Regards,
    2020-01-29T14:17:35+00:00
    YES! This just worked for me as well. Thank you!
    2020-01-29T14:55:54+00:00
    I applied the ssu and this fix and voila!  It be working again.
