Print Management Console Script error?
2019-10-03T13:40:53+00:00
For the last couple of days I get this error when accessing printer properties or just selecting a printer in the print management console:
Anyone else having this issue?  Selecting yes or no has the same effect, i.e., none that I can tell.
I manage several print servers from the management console so looking in my workstation devices and printers isn't the answer. (seemed to be the answer of choice from a similar thread I saw and isn't applicable)
2020-01-29T13:28:52+00:00
This update fixes the issue for current versions of Windows 10 (1903, 1909).
https://support.microsoft.com/en-us/help/4532695/windows-10-update-kb4532695
I just applied this and the Print Mgmt. Console is working again.
69 additional answers
    2020-01-23T21:44:06+00:00
    I have a Windows Server 2019 Print Server. I was experiencing the same issue with the script error. In my case I uninstalled KB4534273. After a reboot, the seemed to resolved. I will talk to our Security Officers to see if there is an upcoming cumulative patch that will correct this.
    I hope this helps.
    2020-01-23T23:14:03+00:00
    I have a Windows Server 2019 Print Server. I was experiencing the same issue with the script error. In my case, I uninstalled KB4534273. After a reboot, the seemed to resolved. I will talk to our Security Officers to see if there is an upcoming cumulative patch that will correct this.
    I hope this helps.
    2020-01-23T23:14:38+00:00
    I hope this helps.
    2020-01-24T08:23:42+00:00
    are this KB include in some other Update, because I do not have installed it alone.
