This update fixes the issue for current versions of Windows 10 (1903, 1909).
https://support.microsoft.com/en-us/help/4532695/windows-10-update-kb4532695
I just applied this and the Print Mgmt. Console is working again.
For the last couple of days I get this error when accessing printer properties or just selecting a printer in the print management console:
Anyone else having this issue? Selecting yes or no has the same effect, i.e., none that I can tell.
I manage several print servers from the management console so looking in my workstation devices and printers isn't the answer. (seemed to be the answer of choice from a similar thread I saw and isn't applicable)
Same here
Windows Server 2019 Std. (17763.914)
Amazing that this is not fixed yet
Microsoft is working on a solution and pans to release an update for Windows in future. Currently uninstalling update KB4517211 may solve the issue
Same here for me
OS Name Microsoft Windows Server 2019 Datacenter
Version 10.0.17763 Build 17763
Fresh brand new build, built early Jan 2020
Hello friends,
I have none of the updates mentioned here and
I have the same issue only when we have extended view showing. )-:
