Hi there,
My problem is small popup window which appears in right bottom corner of the screen each time when I am launching windows explorer.
Would you please advise me how to eliminate the above described problem?
Thanks & Best Regards
Unable to load DLL iaStorAfsServiceApi.dll
Hi there,
Please follow steps on this post and if problem persist, report it through Feedback Hub app.
63 additional answers
2019-11-12T18:40:55+00:00 Awesome. This appears to have resolved the issue! Thank you
2019-11-13T18:04:58+00:00 Dear A.L. I have tried to follow given path (link).
Unfortunately it did not work.
Subjected popup widow with annoying message
Stil shows up.
Best Regards
Piotr
2019-11-13T19:59:36+00:00 Instead of using the App option, please try clicking start, then type "Run" a window will pop up and type appwiz.cpl . That will take you to the Application and Features window. Where you can find Intel Optane Pinning Explorer. Highlight it and select Repair. Once it finishes reboot your machine and see if it still pops up.
