Unable to load DLL iaStorAfsServiceApi.dll
2019-08-18T18:05:48+00:00
Hi there,
My problem is small popup window which appears in right bottom corner of the screen each time when I am launching windows explorer.
Would you please advise me how to eliminate the above described problem?
Thanks & Best Regards
2020-03-18T10:37:20+00:00
Hi there,
Reza-Ameri 45,896 Reputation points Volunteer Moderator
2020-03-30T16:09:58+00:00
Please follow steps on this post and if problem persist, report it through Feedback Hub app.
63 additional answers
    2019-10-21T03:54:25+00:00
    What should I do?
    2019-10-21T03:56:44+00:00
    2019-10-21T05:01:52+00:00
    This was from Unislayer(?)
    The solution is much simpler than all of this:
    In the settings (control panel) under Apps & Features, select the Intel Optane Pinning Explorer Extensions and click "modify".
    This will prompt the app to reinstall itself and solve the problem.  Restart required.
