Unable to load DLL iaStorAfsServiceApi.dll
2019-08-18T18:05:48+00:00
Hi there,
My problem is small popup window which appears in right bottom corner of the screen each time when I am launching windows explorer.
Would you please advise me how to eliminate the above described problem?
Thanks & Best Regards
2020-03-18T10:37:20+00:00
Hi there,
Reza-Ameri 45,896 Reputation points Volunteer Moderator
2020-03-30T16:09:58+00:00
Please follow steps on this post and if problem persist, report it through Feedback Hub app.
63 additional answers
    2020-03-29T18:32:25+00:00
    Hi Thomas,
    Unfortunately, nothing was fixed.
    You have wrong information.
    Piotr
    I know nothing was fixed. What information do I have wrong.?
    Can you clarify.?
    2020-03-30T15:33:19+00:00
    Information that subjected problem has been fixed :-(
    Where do you have that information from?
    2020-03-30T15:55:09+00:00
    Are you saying you fixed the problem.? ..Then asking me where I got the information from.?
    Because I'm still not able to fix the problem.
