Unable to load DLL iaStorAfsServiceApi.dll
2019-08-18T18:05:48+00:00
Hi there,
My problem is small popup window which appears in right bottom corner of the screen each time when I am launching windows explorer.
Would you please advise me how to eliminate the above described problem?
Thanks & Best Regards
2020-03-18T10:37:20+00:00
Hi there,
Reza-Ameri 45,896 Reputation points Volunteer Moderator
2020-03-30T16:09:58+00:00
Please follow steps on this post and if problem persist, report it through Feedback Hub app.
63 additional answers
    2020-03-29T17:35:56+00:00
    I copied all the steps I had to take, go into File Explorer etc. But when I tried to follow them, couldn't find all the things to click on, so I gave up in disgust & switched the thing off.
    Next morning I tried again & hey presto, all the things I had to click on were there, so I did as I was told, then clicked on the last bit, think was 'modify' restarted & it had gone, never to be seen again.
    Margaret
    2020-03-29T18:02:30+00:00
    That's awesome....
    Uh,.. do you remember what " all the things that you had to click on ' ?
    .Crazy..
    Glad you got it fixed.
    2020-03-29T18:21:51+00:00
    Hi Thomas,
    Unfortunately, nothing was fixed.
    You have wrong information.
    Piotr
