Hi there,
My problem is small popup window which appears in right bottom corner of the screen each time when I am launching windows explorer.
Would you please advise me how to eliminate the above described problem?
Thanks & Best Regards
Unable to load DLL iaStorAfsServiceApi.dll
Hi there,
Please follow steps on this post and if problem persist, report it through Feedback Hub app.
63 additional answers
2020-03-24T21:30:53+00:00 Im running this now...at 7% of last promp...sfc /scannow. Guess we'll see what happens....
I'll let you know
2020-03-24T21:44:05+00:00 You may have to do a restore back to Windows10 1809 then update to Winvdows10 1909. A pain but also works.
2020-03-24T21:53:04+00:00 I'd hate the thought of that...re email settings and everything else. Lots involved. At 42%.
I recently updated windows by their prompt. Was on 1809 and can't recall if I had this issue a couple of days ago...?
