Unable to load DLL iaStorAfsServiceApi.dll
2019-08-18T18:05:48+00:00
Hi there,
My problem is small popup window which appears in right bottom corner of the screen each time when I am launching windows explorer.
Would you please advise me how to eliminate the above described problem?
Thanks & Best Regards
2020-03-18T10:37:20+00:00
Hi there,
Reza-Ameri 45,896 Reputation points Volunteer Moderator
2020-03-30T16:09:58+00:00
Please follow steps on this post and if problem persist, report it through Feedback Hub app.
63 additional answers
    2020-03-24T20:03:24+00:00
    I was able to solve this issue by carrying out the following steps:
    (1) go to settings.
    (2) go to apps.
    (3) select Intel Optane Memory
    (4) select Modify
    It looks like nothing happen but go back to restart computer and the message at bottom right hand corner no longer shows.
    2020-03-24T20:48:12+00:00
    I don't have the Intel Optane Memory in my settings. I have Dynamic Platform.., HID Event.., Rapid Storage.., Wireless Bluetooth, Graphics Driver, Management Engine Components, Pinning Explorer Ext.., Wireless Software and Serial IO,..but not Optane Memory. !  ?
    2020-03-24T20:58:14+00:00
    Same here...
