Fans and CPU running very high Windows 10 Build 1903
2019-07-04T15:28:32+00:00
I upgraded to windows 10 version 1903 a few weeks ago.  Shortly afterwards I noticed that my fans were running extremely fast and my CPU temps per core were running in the mid 50s C at system idle.  Previously they were running in the mid to high 30s C.  Task Manager shows my CPU usage at 100%.  I get things back to normal if I disable the Power service, but as soon as I enable it again, my fans begin to race and the temps go up.  My system uses an ASRock motherboard with an Intel i7-8700k and an 8500 watt power supply.  I use the Balanced power setting profile.  Diagnostics for Power doesn't pick up anything and I can't find anything with Google for anyone with a similar problem.  I had a similar issue a couple of years back, but it was caused by me using the High Performance power profile.  Once I changed to the Balanced profile the problem disappeared.  This time, the problem is occurring with the Balanced power setting.  Any suggestions on how to resolve this would be appreciated.
    2019-10-25T14:50:17+00:00
    I have not heard a word from Microsoft or anyone else for the last month and a half.  However, I performed a clean install of Windows 10 build 1903 last Saturday (for other reasons) and the problem does not occur on my system anymore.  I have the power service running and the fans do not race.  This is an FYI.  I'm not stating that  a clean install is the solution to the problem.  I repair PCs and I have such a tremendous amount of diagnostic software and utilities on my system that I am still installing software almost a week later and I have a few more days to go.  With the clean install clearing up the problem, it definitely appears that the problem is Windows related.  I'll keep you posted if the symptoms re-occur while I am re-installing my software.
    Hey there Richard I as well did a complete reinstall and was able to clear the problem as well - It appears that the original upgrade caused issues with a few programs that were at fault - I am not sure that was the problem however I am not seeing the temps.. rise as they were previously - I still believe windows was the issue.   Thank you for your information - I will also keep you updated as I continue to see what and how this happened in the first place - thank you again
    2019-10-25T14:54:13+00:00
    Both richard and I have done a complete reinstall of the window update to 1903 - this is a major time consuming effort since you are wiping your whose drive of everything and this will take time depending on your amount of programs, etc you have - Both Richard and I will update these post if we are able to determine what and why you're not able to update with doing a clean install - we will continue to update this information for you
    2019-10-30T15:26:57+00:00
    hi, i I've figured out this issue that i also experienced. my laptop fan used to be making less sound but after updating windows to 1903 version it occurred and it's kinda frustrating me cause it's noisy.
    I've done so many way to fix this issue but nothing worked. i don't get it but when i turn off the transparency effect in settings, the fan stop making loud sound and spinning as it used to be. i kinda feel weird about this because transparency effect makes your windows appearance looks great.
    i hope this can also help you all to fix this issue
    and i hope Microsoft can fix this issue asap because this is quite annoying
