Glad to hear it, Socram.
Let me know if there's anything else.
Also when ready please mark the post which helped most as the Answer, to help others. A rating is also appreciated.
I'm using Windows 10, and when I try to pair with my DS4 it simply doesn't work. In devices and printers list it shows up as a bluetooth headset and is named just "dongle". In its properties it's said that its manufacturer is KOGA. Apparently it's something about drivers? But I don't know, help!
EDIT: For anyone who may have the problem that I did, I used BlueSoleil to pair my controller and used a program called "World of Joysticks", the xinput emulator one to use it as an xbox 360 controller. Before pairing the controller, make sure you turn off the dualshock 4 support on big picture mode settings, otherwise the computer won't utilize the "xbox 360" controller. Then you just use the standard settings for a dualshock 4 on the app and you're good to go! Thank you very much Greg for all the support you provided me, if it wasn't for you I would not fix this at all!
just found drivers on driver finder websites, but the CSR Harmony is uninstalled. I'm going to try to install it and then see if a different hardware id appears.
The device with the csr harmony installed shows the following hardware id: "{473a6b1d-3407-400e-b91a-f991c5a39dc3}\CsrBtPort". and it's no longer shown under bluetooth, instead, the driver created another category called "CSR BlueICE Device" that has a bluetooth icon, and my adapter is called "Rádio Bluetooth CSR" (Bluetooth Radio CSR). after looking that hardware id on google I found another post here on microsoft of a guy saying that he used bluesoleil and it worked, but i'm not aware if that's an adapter, a software, or both.
I found this: "https://www.sevenforums.com/drivers/338736-csr8510a10-driver-here-available-3.html" but I'm not quite sure if I should trust this forum tho
tried to do it and it did not work :(
