My bluetooth adapter doesn't work properly
2019-08-28T23:04:55+00:00
I'm using Windows 10, and when I try to pair with my DS4 it simply doesn't work. In devices and printers list it shows up as a bluetooth headset and is named just "dongle". In its properties it's said that its manufacturer is KOGA. Apparently it's something about drivers? But I don't know, help!
EDIT: For anyone who may have the problem that I did, I used BlueSoleil to pair my controller and used a program called "World of Joysticks", the xinput emulator one to use it as an xbox 360 controller. Before pairing the controller, make sure you turn off the dualshock 4 support on big picture mode settings, otherwise the computer won't utilize the "xbox 360" controller. Then you just use the standard settings for a dualshock 4 on the app and you're good to go! Thank you very much Greg for all the support you provided me, if it wasn't for you I would not fix this at all!
Greg Carmack 24,780 Reputation points Volunteer Moderator
2019-09-02T15:19:52+00:00
Glad to hear it, Socram.
Let me know if there's anything else.
Also when ready please mark the post which helped most as the Answer, to help others.  A rating is also appreciated.
45 additional answers
    2019-08-28T23:25:12+00:00
    Hi Socram. I'm Greg, an installation specialist, 10 year Windows MVP, and Guardian Moderator here to help you.
    See fixes working for DS2 bluetooth failure to connect:
    https://www.reddit.com/r/PS4/comments/5hoci3/fi...
    https://www.reddit.com/r/techsupport/comments/8...
    https://answers.microsoft.com/en-us/windows/for...
    https://gamefaqs.gamespot.com/boards/916373-pc/...
    https://www.cnet.com/forums/discussions/dualsho...
    I'll give all possible steps for troubleshooting Bluetooth in order of priority. Many problems right now are being solved by updating to the latest version so if you want to skip to that step see the Repair Install at bottom:
    Make sure you're pairing correctly as shown here: https://support.microsoft.com/en-us/help/15290/...
    See Fixes here which are all working:
    https://support.microsoft.com/en-us/help/14169/...
    https://superuser.com/questions/1017867/make-wi...
    Try the Bluetooth troubleshooter at Settings > Update & Security > Troubleshoot.
    Try turning off Fast Startup at Settings > System > Power & Sleep > Additional Power Settings > Choose what Power buttons do > Change settings that are unavailable > uncheck Fast Startup.
    If this is a mic or headset right click Volume icon in System Tray to Open Sound Settings, make sure the correct device is selected for input or output in the dropdown menu.
    Try Updating the Bluetooth driver from the PC maker's Support Downloads webpage for your exact model. Install it even if it's the same or newer than the one in Device Manager reached by right clicking the Start button.
    Right click Start button to access Device Manager, locate Bluetooth device (if necessary from View tab Show Hidden Devices), on Driver tab see if Roll Back is available, if not try Update Driver, first automatically, then Browse, then Let Me Pick to try all previously installed Drivers.
    If these fail try to Uninstall the Driver, restart PC to reinstall.
    Then try pairing again, if necessary run the Bluetooth Troubleshooter again.
    If this was caused by Windows Updates then you can check which were installed at Settings>Update & Security>Windows Update under Installed Updates, then uninstall them from the link there, and hide with the Hide Updates tool downloaded from here: http://download.microsoft.com/download/f/2/2/f2...
    You can also use System Restore to get before the problem began, then check for Updates with the Hide Update tool and hide them: http://home.bt.com/tech-gadgets/computing/how-t...
    If this was caused by a Version Update then for 10 days you can roll it back in Settings>Update & Security>Recovery and then hide it until it matures using the Hide Updates Tool which is explained more here:
    https://www.howtogeek.com/223864/how-to-uninsta....
    Go over this checklist to make sure the install is set up correctly, optimized for best performance, and any needed repairs get done: http://answers.microsoft.com/en-us/windows/wiki...
    Start with Step 4 to turn off Startup freeloaders which can conflict and cause issues, then Step 7 to check for infection the most thorough way, then step 10 to check for damaged System Files. Then continue with the other steps to go over your install most thoroughly.
    If nothing else helps you can run a Repair Install by installing the Media Creation Tool and choosing from it to Upgrade Now. This reinstalls Windows in about an hour while saving your files, apps and most settings, solves many problems while also bringing it up to the latest version 1903 which you need anyway and by the most stable method. http://windows.microsoft.com/en-us/windows-10/m....
    I hope this helps. Feel free to ask back any questions and let us know how it goes. I will keep working with you until it's resolved.
    ________________________________________________________
