Xbox One Controller not connecting via Bluetooth after being plugged in with USB
2019-09-20T00:45:11+00:00
I have a Xbox One Wireless Controller without the PC adapter so I use Bluetooth to connect directly to my PC.  After charging the controller through one of my PC's USB ports while the PC is on, once the USB to the controller is disconnected it can no longer connect via Bluetooth.  It will still work while the USB is connected but won't work via bluetooth.
Trying to un-pair the controller or uninstall it through devices or device manager often doesn't uninstall.  The most successful method of getting it to work again is to un-pair in the Bluetooth devices and uninstall in both the devices and printers and device manger, then restarting the PC and attempting to pair via Bluetooth again.  This works most of the time but occasionally won't work.
I assume this problem is related to Windows or driver as the device still works perfectly when it is connected via USB. It is like it is flipping a switch to say that it is USB only when it detects the USB connection.
A solution to this problem would be appreciated as I only have 1 USB cable long enough to reach my gaming position and if my headset goes flat while my controller is charging, I have to spend 20+ minutes trying to get the controller to work again via Bluetooth.
Thanks.
2020-05-16T21:29:34+00:00
Hi everyone,
Improved Solution:
  1. Settings > Devices > Bluetooth & Other Devices
Find Xbox Wireless Controller and Remove Device.
  1. Windows Search > Device Manager > View > Show Hidden Devices
Find "Human Interface Devices" and uninstall HID-compliant game controller.
*Important to "Show hidden" or you won't find it as the device is disconnected*
  1. Go through the normal pairing process. *Turn on Bluetooth*
Settings > Devices > Bluetooth & Other Devices > "Add Bluetooth or other device" > Bluetooth.   Don't use "Everything else" even though it says Xbox controllers.
  1. Turn on your Xbox controller and press the sync button. You should now be able to pair AND connect to your computer.
I really hope this was the main and only issue. If it isn't, go into my last post for the clean slateidea. Upvote if this worked!
2020-01-04T13:05:04+00:00
I had a similar problem (although I could repair controller without PC restart)
I found a workaround:
  1. Connect controller via USB
  2. Go to win+X -> device manager and disable (not delete) Xbox one controller here
  3. After that repair controller via Bluetooth
Thus when you connect controller via USB it will only charge but will not connect as a device - and Bluetooth connection will remain connected
I have win 10 1909
115 additional answers
    2020-07-31T06:23:34+00:00
    I am going through the same issue, but much worse. I just bought everything two weeks ago. used my new Wireless Xbox controller connected to my Windows 10 via Bluetooth. Out of curiosity, I attached a USB cable to my controller from my PC and now I can't use my Bluetooth. Since it cant be recognized in the Bluetooth devices, I went straight to "device and printers" and deleted the controller. After that, I went to the device manager and saw no Microsoft Xbox option so I just restarted my PC. Went to turn my PC's Bluetooth back and pressed the xbox button but it would only blink unless you keep holding the button itself and stops the moment you lift your finger off it. Im so pissed and I don't even know what to do now. Also, that USB cable was wonky too - at a certain angle of the cord, it wont work with the controller. I need some serious help.
    2020-07-31T06:39:21+00:00
    I am going through the same issue and Im so pissed. I don't even know what to do now. Also, I was using a USB cable was wonky too - at a certain angle of the cord, it wont work with the controller. I followed ChessScholar's solution but my situation is kinda different.
    1. I can't unpair my wireless xbox 1 controller in the Bluetooth area because it's not paired in the first place.
    2. Went to show hidden devices then to human interface devices and can't find HID compliant game controller nor anything that says system controller. I have a bunch of HID complaints that say consumer control device and vendor define device. uninstalled those and went through the normal process of connecting via Bluetooth.
    I got nada doing it. My controller blinks ONLY if you keep holding the Xbox button. Once you take your finger off it, there's no more blinks. IM SO STRESSED!
    2020-08-06T17:00:43+00:00
    This is annoying as hell.
    Cheap AF controllers from a shady kiosk are able to simply reconnect but my xbox one controller cant?
    Microsoft - give us a damn fix
