Xbox One Controller not connecting via Bluetooth after being plugged in with USB
2019-09-20T00:45:11+00:00
I have a Xbox One Wireless Controller without the PC adapter so I use Bluetooth to connect directly to my PC.  After charging the controller through one of my PC's USB ports while the PC is on, once the USB to the controller is disconnected it can no longer connect via Bluetooth.  It will still work while the USB is connected but won't work via bluetooth.
Trying to un-pair the controller or uninstall it through devices or device manager often doesn't uninstall.  The most successful method of getting it to work again is to un-pair in the Bluetooth devices and uninstall in both the devices and printers and device manger, then restarting the PC and attempting to pair via Bluetooth again.  This works most of the time but occasionally won't work.
I assume this problem is related to Windows or driver as the device still works perfectly when it is connected via USB. It is like it is flipping a switch to say that it is USB only when it detects the USB connection.
A solution to this problem would be appreciated as I only have 1 USB cable long enough to reach my gaming position and if my headset goes flat while my controller is charging, I have to spend 20+ minutes trying to get the controller to work again via Bluetooth.
Thanks.
2020-05-16T21:29:34+00:00
Hi everyone,
Improved Solution:
  1. Settings > Devices > Bluetooth & Other Devices
Find Xbox Wireless Controller and Remove Device.
  1. Windows Search > Device Manager > View > Show Hidden Devices
Find "Human Interface Devices" and uninstall HID-compliant game controller.
*Important to "Show hidden" or you won't find it as the device is disconnected*
  1. Go through the normal pairing process. *Turn on Bluetooth*
Settings > Devices > Bluetooth & Other Devices > "Add Bluetooth or other device" > Bluetooth.   Don't use "Everything else" even though it says Xbox controllers.
  1. Turn on your Xbox controller and press the sync button. You should now be able to pair AND connect to your computer.
I really hope this was the main and only issue. If it isn't, go into my last post for the clean slateidea. Upvote if this worked!
2020-01-04T13:05:04+00:00
I had a similar problem (although I could repair controller without PC restart)
I found a workaround:
  1. Connect controller via USB
  2. Go to win+X -> device manager and disable (not delete) Xbox one controller here
  3. After that repair controller via Bluetooth
Thus when you connect controller via USB it will only charge but will not connect as a device - and Bluetooth connection will remain connected
I have win 10 1909
115 additional answers
    2019-09-20T01:30:51+00:00
    Hi , I'm David, thanks for participating in the Microsoft Community. I'll do my best to help today.
    Regards Wayne_Carr, Please follow the instructions to Connect and troubleshoot Bluetooth on your Xbox One wireless controller.
    https://support.xbox.com/en-US/xbox-on-windows/...
    Best Regards,
    David.
    2019-09-20T13:35:11+00:00
    Do you guys actually read the posts and the suggestions that you provide?  I stated almost everything that is in that link in my original post, including the steps that make it work again.
    The problem is that I have to do it every time that I need to plug the controller in via USB while the PC is on.  There is obviously a problem with the way that Windows controls the device, it disables the Bluetooth connection and doesn't re-enable it once it is unplugged from USB.
    I am looking for a way to not have to spend 20 minutes troubleshooting this every time I need to charge it.
    2019-09-21T03:13:05+00:00
    Hi Wayne
    My name is Andre Da Costa; an Independent Consultant, Windows Insider MVP and Windows & Devices for IT MVP. I'm here to help you with your problem.
    What is the exact make and model?
    Open Start, type: system information
    Hit Enter
    Click System summary
    Look in the right pane
    Copy the system sku info into reply here.
    See example: https://imgur.com/qzektpA
    If its custom built, what is the make and model of your motherboard?
    It is possible you might need to update your BIOS and chipset drivers.
    Which version of Windows 10 is currently installed? See how to verify:
    https://answers.microsoft.com/en-us/windows/wik...
    In the mean time, try disabling fast startup:
    Disable Fast Startup, then try again.
    Press Windows key + X
    Click Power options
    Click Additional power settings under Related settings
    Click Choose what the power button does
    Click Change settings that are currently unavailable
    Uncheck 'Turn on fast startup (recommended)
    Click Save changes.
    Click Restart now and see if it works.
    If it does not help, to isolate if this is a user profile issue.
    Could you confirm if this also happens in the default Administrator account?
    Open Start
    Type: cmd
    Right click CMD
    Click Run as administrator
    At the command prompt, type:
    net user administrator /active:yes
    Hit Enter
    Close command prompt, restart, then try signing into the Administrator account.
    The default Administrator password should be blank.
    Try setting up the device again.
