Latest version of what? Windows? Or the Microsoft Store. Found out today that Microsoft Store is a thing and it can be updated.
Switching out of S mode : Blank screen
Whenever I open the Microsoft store to switch out of S-mode. A Button reading "learn more" appears, however whenever I click this the store loads a completely blank gray screen, is there another option to switch out of S-mode, or is the link to the store broken?
2019-08-02T00:54:54+00:00 -
2019-08-02T01:28:03+00:00 OKAYYYYYYYYYYYYYYYYYYYYYYYY FINALLY IT'S OKAY !!! Go to the Microsoft store, clik on the three points on the up right corner, choose download update, on the page click get updates, then Microsoft store will update and it will work again!!
Yes, FINALLY, just did an update of microsoft store, did the switch to windows 10 home under settings>activation, went to Store and got the switch out of S mode. HOORAY
and first thing I did was download Chrome......
Good luck everyone.
2019-08-02T14:23:54+00:00 Can confirm; it's fixed for me on my Lenovo netbook!
2019-08-02T14:33:33+00:00 Yay I am finally out of S mode. To fix it got the windows store > downloads and updates > click microsoft store app > click the three dots next to launch and click update. After that the page should no longer be blank.
2019-08-06T18:02:42+00:00 You need to make sure the you are running MS Store version: 11906.1001.24.0
in order to be able switch out from S Mode
Sometimes even though after update the MS store to the latest version you could face this other issue:
In that case you will need to download the ISO file and run the Setup from Sources Folder [That will be like Custom Install].
When this process finish The Get option will not be longer grey out and you can switch out from S Mode.
