Switching out of S mode : Blank screen
2019-07-29T22:33:39+00:00
Whenever I open the Microsoft store to switch out of S-mode. A Button reading "learn more" appears, however whenever I click this the store loads a completely blank gray screen, is there another option to switch out of S-mode, or is the link to the store broken?
    2019-08-01T16:56:56+00:00
    No good for me. In fact, I think it installed Win 3.1. That isn't right, is it?
    2019-08-01T19:23:50+00:00
    Also having the same problem. Have to get an important work computer up and running in like four hours and need to install some third party stuff, including display drivers for an external display. It's been 24 hours ish, is that fix coming?
    2019-08-01T20:54:48+00:00
    I've maybe find a way to go through that, just download this https://www.microsoft.com/fr-fr/software-download/windows10 start the instalation as usual and choose to update this pc, it should solve the issue, I'll update you guys to let you know if it worked.
    2019-08-01T20:59:52+00:00
    This is the error message in event viewer. It is a KNOWN MICROSOFT PROBLEM. Dont mess your pc up trying to fix what they have broken just wait.     Failure invoking ms-windows-store://switchwindows/: action switchwindows not recognized
    Error Code: Unknown HResult Error code: 0x80000000
    Function: InvokeUri
    Source: C:\BA\39\s\src\Core\ProtocolActions\ProtocolActionHandler.cs (108)
    2019-08-01T21:07:33+00:00
    There is no wuauserv in win 10 s what are you talking about ?????
