KB4516065 Installation Fails with Error 80092004
2019-09-13T16:27:07+00:00
This is the only patch that is getting an error at installation. I've tried update troubleshooter, standalone install and clearing Software Distribution folder without success. Are others having this issue?
2019-09-14T01:44:19+00:00
Had the same problem. What fixed it was to download these two KBnnnnnn patches from the Windows Update Catalog.
KB4490628  (make sure this one gets installed successfully first)
KB4516065
*************************Links Added By VM July 2, 2021******************************** https://www.catalog.update.microsoft.com/Search.aspx?q=KB4490628
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4516065
88 additional answers
    2019-09-26T19:05:46+00:00
    Thanks for thew reply.
    You're welcome. The guy didn't reply to you. You seem to be completely unaware this topic may not even cover your issue. It's not about KB4516065 failing with some error. It's about some KB failing with error 80092004.
    2019-09-27T17:20:25+00:00
    Go to https://www.catalog.update.microsoft.com/Home.aspx and enter KB4490628. Download, run and install it.
    Hope this helps!
    2019-09-29T16:15:25+00:00
    THANKS LOT , WORKED FOR SERVER 2008 R2 ENTERPRISE
    2019-09-29T19:17:32+00:00
    In reply to SpikeyMusik - Actually the error showing on my failure was 800F0900 not what you have inidcated
