KB4516065 Installation Fails with Error 80092004
2019-09-13T16:27:07+00:00
This is the only patch that is getting an error at installation. I've tried update troubleshooter, standalone install and clearing Software Distribution folder without success. Are others having this issue?
2019-09-14T01:44:19+00:00
Had the same problem. What fixed it was to download these two KBnnnnnn patches from the Windows Update Catalog.
KB4490628  (make sure this one gets installed successfully first)
KB4516065
*************************Links Added By VM July 2, 2021******************************** https://www.catalog.update.microsoft.com/Search.aspx?q=KB4490628
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4516065
88 additional answers
    2020-03-01T20:51:32+00:00
    Then there are some more steps you can try prior installation.
    sfc /scannow
    DISM /online /cleanup-image /scanhealth
    are there any reported errors?
    2020-03-20T13:18:35+00:00
    Thank you, you helped me as well!
    2020-03-25T22:42:30+00:00
    This workefor me too. I have been struggling with this for 2 months !
    Thanks a lot
    2020-03-29T14:12:53+00:00
    KB4516065
    I had to reply to this. I was baffled as to why my updates kept on failing every single time i tried them...it was driving me crazy because windows update was eating a lot of memory in the background. I saw this post and figured Id give it a try...and it worked, perfectly. As soon as I dl'd "628", the others all downloaded and installed fine. Thanks you for this.
