KB4516065 Installation Fails with Error 80092004
2019-09-13T16:27:07+00:00
This is the only patch that is getting an error at installation. I've tried update troubleshooter, standalone install and clearing Software Distribution folder without success. Are others having this issue?
2019-09-14T01:44:19+00:00
Had the same problem. What fixed it was to download these two KBnnnnnn patches from the Windows Update Catalog.
KB4490628  (make sure this one gets installed successfully first)
KB4516065
*************************Links Added By VM July 2, 2021******************************** https://www.catalog.update.microsoft.com/Search.aspx?q=KB4490628
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4516065
88 additional answers
    2020-01-06T10:30:53+00:00
    Thank you lintekPC. Installing KB4490628 did the trick.
    2020-02-22T11:41:05+00:00
    I have read through this thread and am still stuck on installation of this update.
    KBKB4490628 was already installed previously.
    KB4516065 is still failing install
    Windows 7 Pro user.
    Any further thoughts?
    2020-02-22T14:09:21+00:00
    At this point in time I suggest you download the Windows 10 installation media creator from:
    https://www.microsoft.com/en-us/software-download/windows10
    and create a bootable USB. Dont forget to select the language and x86/x64 version of the current installation of Windows 7.
    Then you will be able to upgrade your Windows 7 Pro to Windows 10 Pro retaing (allmost) all the apps and data. (yup, it still works)
    You have to run the setup from within the existing installation of Windows 7. To be sure, create a full system backup.
    2020-02-29T17:20:33+00:00
    KB4516065
    Thanks, this worked perfectly on my Win 7 pro testing Virtual Machine.
