KB4516065 Installation Fails with Error 80092004
2019-09-13T16:27:07+00:00
This is the only patch that is getting an error at installation. I've tried update troubleshooter, standalone install and clearing Software Distribution folder without success. Are others having this issue?
2019-09-14T01:44:19+00:00
Had the same problem. What fixed it was to download these two KBnnnnnn patches from the Windows Update Catalog.
KB4490628  (make sure this one gets installed successfully first)
KB4516065
*************************Links Added By VM July 2, 2021******************************** https://www.catalog.update.microsoft.com/Search.aspx?q=KB4490628
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4516065
88 additional answers
    2019-12-30T20:17:09+00:00
    Hello, this fix worked out the box for me. I had been tussling with a few machines that encountered this problem. Tried all kinds of fixes. The main difference with this fix was ensuring KB4490628 was installed first. Once I did that the other updates worked as intended.
    Thank you
    2020-01-02T14:48:14+00:00
    Thanks a lot.
    I've been struggling for days with this problem.
    Following this link helped me to solve my problem.
  3. Deleted
    2020-01-04T10:40:44+00:00
    Thanks so much! ~
