KB4516065 Installation Fails with Error 80092004
2019-09-13T16:27:07+00:00
This is the only patch that is getting an error at installation. I've tried update troubleshooter, standalone install and clearing Software Distribution folder without success. Are others having this issue?
2019-09-14T01:44:19+00:00
Had the same problem. What fixed it was to download these two KBnnnnnn patches from the Windows Update Catalog.
KB4490628  (make sure this one gets installed successfully first)
KB4516065
*************************Links Added By VM July 2, 2021******************************** https://www.catalog.update.microsoft.com/Search.aspx?q=KB4490628
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4516065
88 additional answers
    2019-11-18T07:31:32+00:00
    It's worked for me ! Thank you so much
  2. Deleted
    2019-11-29T02:02:14+00:00
    In addition, I also saw reference to making sure kb4474419 was installed successfully.   I have checked my install history and both is one and kb449028 were installed successfully.
    Is it possible that these have to be installed again for kb4516065 to work?   Who knows but this is frustrating.
    In my case KB4474419 was previously installed. However, Microsoft recommends that KB4516655 also be installed before KB4516065. KB4516655 would not install on my PC until I installed KB4490628. So, you might confirm that you have KB4516655 installed as well.
    Here are the Microsoft Update Catalog links if needed for manual install in the order that I installed each one.
    https://www.catalog.update.microsoft.com/Search.aspx?q=KB4516655
    OUgrad
    2019-11-29T23:24:51+00:00
    KB4516065
    YES! Thanks so much!
